Seat Memory Module
Hi Everyone,
I have a 2011 Q5 and for the last few days I've been having issues with the seat memory adjustment.I am not able to recall the setting for position 1 or 2, the off button seems to work fine (yellow light turns on), my seats do not adjust automatically based on the key you use to open the door and I cannot save a seat position. I tried resetting the position limits by going up/down, forward/back etc, but that didn't make a difference. I am stuck.... Could it be a faulty module? Thanks
When I ran vag-comm I got the following:
Address 36: Seat Mem. Drvr Labels: NONE
Control Module Part Number: 8Z0 959 760 J HW: 8R0 959 760 B
Component and/or Version: MEM-FS H06 0074
Software Coding: 00000000000000000000
Work Shop Code: WSC 06335 000 00000
VCID: 50AFC64103E334CA05-8004
3 Faults Found:
16347 - Control Module - EEPROM Error
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 133
Mileage: 0 km
Time Indication: 0
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 133
Mileage: 108395 km
Time Indication: 0
Date: 2020.06.02
Time: 18:20:23
00461 - Control Module for Seat Memory; Passenger (J521)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 133
Mileage: 108395 km
Time Indication: 0
Date: 2020.06.02
Time: 18:20:28
Monday,20,July,2020,12:43:12:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
Address 36: Seat Mem. Drvr Labels: None
5 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 197
Mileage: 0 km
Time Indication: 0
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 197
Mileage: 109529 km
Time Indication: 0
Date: 2020.07.20
Time: 12:35:10
03330 - Motor for Fore/Aft Adjustment
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 197
Mileage: 109529 km
Time Indication: 0
Date: 2020.07.20
Time: 12:35:10
03331 - Motor for Backrest Angle Adjustment
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 197
Mileage: 0 km
Time Indication: 0
03332 - Motor for Height Adjustment
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 197
Mileage: 0 km
Time Indication: 0
3 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 133
Mileage: 0 km
Time Indication: 0
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 133
Mileage: 108395 km
Time Indication: 0
Date: 2020.06.02
Time: 18:20:23
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 133
Mileage: 108395 km
Time Indication: 0
Date: 2020.06.02
Time: 18:20:28
www.Ross-Tech.com
5 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 197
Mileage: 0 km
Time Indication: 0
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 197
Mileage: 109529 km
Time Indication: 0
Date: 2020.07.20
Time: 12:35:10
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 197
Mileage: 109529 km
Time Indication: 0
Date: 2020.07.20
Time: 12:35:10
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 197
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 197
Mileage: 0 km
Time Indication: 0
Did you ever clear the codes? If you did and the second scan is after clearing then first find the connector(s) involved and wiggle them to see if that gets it working. You can go into VCDS to "see" the module and what the wiggling the connector does.
If that gets it working and it quits again you may need to clean the connector(s). If that doesn't get the module working then try removing power to it then power it back up. That module is always powered so you need to find a fuse or unplug it to re-boot it.
Jessyjey
S4 (B8 Platform) Discussion
09-24-2020 10:17 PM
WODT-Sanders
4.2 V8 Discussion
06-15-2019 07:46 PM
ceroberts75
03-10-2018 09:03 AM
