Shifter & Door Sill mods
Old 06-23-2012, 10:52 PM
  #11
alvinfromhawaii's Avatar
Originally Posted by spijun
Maybe this help:
Thanks!
Old 06-24-2012, 07:50 AM
  #12
maynard0418's Avatar
Originally Posted by ThunderDent
Straightened the pin up this morning. Everything looks really straight (90 deg) and even (from top down). Shifter sits completely down with ease, but the pin still stays stuck in the "in" position.
We have tried everything, filing, trying to check it with some sort of indicator. Tried marking it, markered it dark and applied talc, applied lubricant grease... All in an attempt to see where that damn pin is hitting heavy when pressed.
Thanks goodness we fabricated a device to pop that shift pin back out because I've had to use it almost 10 times.
So at this point it's still stuck in place. Going to work on it some more in a bit.
I think it's hitting on the top, but I really have no idea. I may be driving around with my shifter ways pressed in.
Really tough mod.
ThunderDent,
Where did you buy your S-Line door sills?
Old 06-25-2012, 03:55 PM
  #13
ThunderDent's Avatar
BKS Tuning. Their website is a cluster, but the sills fit the Q5 and are OEM.
All the sills are actually the same. The molded plastic on the inside has all the part numbers it could be, depending on the aluminum insert.
Think the only place that gets these is overseas.
afretes
12-20-2005 03:26 PM
RC
Audi Original "S" Cars
12-15-2005 07:23 AM
moribundman
12v V6 Discussion
20
08-14-2004 10:58 PM
j31izzle
15
05-16-2002 03:29 PM
ScottAW
02-21-2001 12:27 PM
Quick Reply: Shifter & Door Sill mods
