Snow driving question
#11
a word of warning about going in reverse to get through snow, the plastic skid plate is not that sturdy. ...
There are two pieces, a front one that ties into the front bumper and goes back to just past the centerline between the front wheels. It clips into the back piece that extends another 18" or so. Where the two pieces join, the snow had caught and popped the clips out and must have folded the piece back because now it is torn. I guess i will have to have it replaced. Luckily the clips were still there, so for now i have it put back together, but it is pretty damaged. I should have just stayed home today!
That is why I was looking to get a metal skid plate.
#12
<a href="http://s131.photobucket.com/albums/p315/hoscarnag/?action=view&current=Audi1.jpg" target="_blank"><img src="http://i131.photobucket.com/albums/p315/hoscarnag/Audi1.jpg" border="0" alt="Photobucket"></a>
#13
What happens with the torsen is that if either the front or rear axles are spinning, the center diff acts as an open diff so now power goes to the rear thinking the car has power. Inclines and low traction are the enemy of Quattro. They are working on fixing this. I know exactly how you feel as I too have been in this situation.
#14
To do this front and rear the brakes would have to be applied to both wheel on the front or rear axle depending which has traction and which doesn't. That wouldn't work very well because now your other axle will moving while one isn't. Audi is working on the new crown gear center diff which would fix this. along with torque vectoring rear diff.
If your rear wheels are spinning stuck and the fronts have traction i believe if you enable the parking brake which locks the rear wheels you are basically doing what you mentioned about a center diff EDL.
#15
Thank you, but it looks to me like part #6 may be the panel on the side. The piece that was damaged actually covers the oil pan. it is attached to the front bumper and extends back roughly the middle of the front wheels, where it ties into what i think are pieces #5 and #6 in the diagram. I will try to get a picture of it tonight. BTW, where did you order from? I can't seem to find it on-line. I am calling the dealer soon, so I will report back.
#17
#18
I don't think it hit anything hard, just a bunch of fresh snow. i think the snow just wedged in the seam and it acted like a shovel scooping up the snow until it bent backward. I had the water pump replaced a few weeks ago, so maybe it wasn't re-installed completely tight. Anyway, it is an expensive piece. First Dealer quote is $380 for the part, $80 minimum for install. I am going to keep checking.
audi_q7101
Q7 MK 1 Discussion
13
02-10-2017 02:50 AM
gofastblue
12-13-2005 07:08 AM
gofastblue
01-04-2005 09:00 PM
Bluto
12
12-01-2002 04:43 AM
Agent Orange
11-04-2002 05:20 AM
