Subwoofer Upgrade Project
#111
Get your flamesuit on. I yanked out the B&O. Went from 14 to five speakers and it is actually better. The B&O is crap. If it sounds good to you, you are lucky. The more i lestened to it the more I could not stand it. However B&O does use MOST bus which means you can get a very clean signal with a MoBridge.
#112
"Do you know how to get aux level out from the subwoofer amplifier. "
Maybe I'm missing something here, but in an OEM setup? There's no reason to have any "aux" (i.e. low level) output from the subwoofer amplifier, since that amplifier is built for only one purpose: Driving a speaker. The subwoofer.
I'd be very surprised if an OEM subwoofer amp had anything besides speaker-level outputs.
Aftermarket amplifiers...anything is possible.
#113
Bottom line, I don't believe there is an analog aux level signal available. Are you sure you are missing frequencies? The sub amplifier you installed would typically have an adjustment **** for the low pass filtering. If you turn it to the highest frequency setting, it should amplify the subwoofer signal with minimal additional roll off.
saucys4
09-27-2008 02:38 AM
siberian
09-11-2003 01:46 PM
Straz (parting out)
05-07-2002 01:07 PM
Aftershock
09-11-2000 06:43 PM
