VAG-COM codes
#121
Yes, that's the one you will need. You can verify by poking around the Ross-Tech site and go to application for Q5.
#122
#125
#126
How would they know you messed with everything if you just put it back to normal before you take it to the dealer? I'm not aware of any "logging" feature that the dealers can use against you......
#127
#128
I just Vag-Com'ed all the features mentioned in this thread. Any new ones that you've heard of recently? Also, has anyone played around with the MMI hidden menu? I only added the battery indicator function. In the last screen shot in the link below, there's a "copy/ripping" option under "import multimedia". Default was "copy/no ripping". I changed this to "copy/ripping" hoping to be able to import tracks directly from a CD to the Jukebox, but it doesn't work. Any ideas what this may be for?
http://trick77.com/2009/07/23/unlock...g-hidden-menu/
#129
#130
For any new owners that plan to do some VAG-COM "upgrades", here is a link to some helpful info about settings.
- Gauge sweep
- Lap timer (& oil temp)
- Key warning
- Economy shift suggestion
- Convenience windows
- Winking DRL
Just FYI,it seems like Audi service loves doing a reset back to default NA settings during a service, so be prepared to repeat from time to time. But its well worth it!
http://forums.quattroworld.com/q5/msgs/829.phtml
- Gauge sweep
- Key warning
- Winking DRL
