VAG-COM codes
Old 02-14-2011, 01:32 PM
  #211
Ed@mtl's Avatar
Originally Posted by 1atlas
Tried this and when selected mod 56 the display read diagnostics in process and just made on off hum sound. Canceled it out. Was this normal and should I wait longer for it to run through?
I can't remember. I didn't have any issue with this.
Old 02-18-2011, 01:02 PM
  #212
abacon09's Avatar
Originally Posted by ukjeeper21
So the emergency braking mod works...I accelerated to about 55-60 mph and slammed on the brakes. I don't have any video editing software so the actual demonstration is at the 50-60 sec mark...
ukjeeper21, can you verify this is the code you input to make the emergency brake lights work. This is what I input but I wasn't able to get them to work when I was braking hard on my street. I probably wasn't braking hard enough though. Thanks
[46 - Comfort System]
[Coding - 07] -> [Long Coding Helper] -> Byte 8:
Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
Old 02-19-2011, 06:26 AM
  #213
DrV
DrV's Avatar
Originally Posted by Ed@mtl
changing in module 56 - Radio byte 12, setting bit 0 from 0 to 1 results in an "S5" logo on the splashscreen (the startup screen on the radio), setting bit 1 from 0 to 1, results in an "RS" splashscreen. Setting both bits 0 and 1 from 0 to 1 results in an "S" logo."
I tried this, but "56 Radio" long code helper is only 9 bytes long - no byte 12.
Can someone clarify?
Old 02-20-2011, 09:49 AM
  #214
Ed@mtl's Avatar
What Vagcom version software are you using? I tried it again and it works for me.
I found a screen shot for you:
http://www.a5oc.com/forums/attachmen...0&d=1268759048
Old 02-20-2011, 11:49 AM
  #215
Stuttgartrob's Avatar
Can the region be changed on the DVD player with this software?
Old 02-20-2011, 12:23 PM
  #216
DrV
DrV's Avatar
I'm using the newest version, however as far as I know that should not matter. Thanks for the screenshot. Perhaps it's my MMI version that's older than yours.
Old 02-20-2011, 12:42 PM
  #217
Ed@mtl's Avatar
Humm, I notice that you have Nav which I don't. Maybe this makes a difference? With Nav you can access the hidden meun and change the splash screen from there:
http://trick77.com/2009/07/23/unlock...g-hidden-menu/
Old 02-21-2011, 03:16 AM
  #218
DrV
DrV's Avatar
Thanks, I forgot about the hidden menu! I'll check it out today.
Old 02-24-2011, 07:59 AM
  #219
uberwgn's Avatar
WOW, great stuff in this thread. I love the emergency braking light config...that's pretty awesome for those of us living in the land of tailgaters.
I'm surprised nobody has been able to figure out how to turn OFF the TPMS on a car like our 2006 Avant.
Old 02-24-2011, 12:31 PM
  #220
tgt
tgt's Avatar
Great video! I did this (among others) VAG changes a couple of months ago and have been wondering if this specific coding had worked.
-tgt
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/FYPxx4NqpNo?hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/FYPxx4NqpNo?hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Quick Reply: VAG-COM codes
