VAG-COM codes
#262
If, for example, we know we want a particular Driive Select option, can we turn it on via VAG, turn on hidden MMI menu via VAG, select the drive option, and then turn off the hidden menu and still have the selected Drive Select work as wanted?
I ask because I'm a bit weary of having the MMI Hidden Menu on full time - isn't there a hidden menu option that is a no-no to touch? I don't trust car riders not to accidentally fool with the MMI and not hit that no-no option.
#263
All that said. I do believe you can make the change and then turn the hidden menu back off if you really wanted to.
Hope that helps,
tgt
#264
Valid question, however, in my eyes it's not much of a concern. The 'hidden' manu is accessed by holding down two buttons on the MMI controls for 5-6 seconds (fully documented at that link above). I think the chances of holding down the correct 2 buttons for 5-6 seconds are slim to none. ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Hope that helps,
tgt
Hope that helps,
tgt
#266
You could do this by changing the adaptations to 3 (instead of 4) to always be in Dynamic instead of Individual (which is what puts the options on the MMI display).
#269
Is it,
[Coding - 07] -> [Long Coding Helper] -> Byte 8 -> Bit 2 change 0 to 1
[Coding - 07] -> [Long Coding Helper] -> Byte 8 -> Bit 4 change 0 to 1
or,
[Coding - 07] -> [Long Coding Helper] -> Byte 8 -> Bit 1 change 0 to 1
#270
Which Byte 8 Bit did you end up changing from 0 to 1?
Is it,
or,
Is it,
or,
