VAG-COM (VCDS) Gear Display Question
For those of you who have made the VAG-COM change to always show the gear you're in on the dash in both Drive "D" and Sport "S" modes, does it also still display the "D" or "S" on the dash screen, or do you lose that? If you lose the "D" or "S" on the dash screen, how do you know if you're in Drive or Sport mode?
It would be great to have the VAG-COM change to know what gear you're in before you start downshifting, but not sure if I'd want to lose the ability to know if the car was in Sport or Drive (although I suppose you could probably tell the difference by how the car is shifting).
Thanks!
Thanks!
Without making this change, what is displayed when new? I remember seeing D1, D2, D3, etc. when test driving a new Q5 2.0T. Also, can a modification be made with Vag-Com to tighten the steering on a 2.0T, which unlike the 3.0T doesn't have the drive select feature available? Thanks.
Thanks!
Thanks!
Enable Automatic Gear selection shown in DIS
[02 Auto Trans] [Adaptation 10]
Select Single Gear Display from top channel drop down menu
Select D on/S on from New value drop down menu
Brrr...
I think you should be banned for showing -13 degrees no matter WHAT the scale![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
I'm sitting on the back porch barefooted and very warm in short sleeves and shorts !
