VCDS (VAG COM) and rear hatch
#11
It is possible the model Q5, if you have:
Electric tailgate opening and closing
The electric operation makes it easier to open and close the tailgate
Open on button on the car key, key in the driver door trim and soft touch button in the finger grip of the boot lid, closing on button on the inside of the boot lid, with closing and programmable opening angle of the tailgate
http://www.kufatec.com/index.php?mai...03t0o8dn5v4oc1
Opening and closing windows and panoramic glass roof is standard
Enable Remote Operation Windows and Sunroof
[46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
Bit 2 - Set to 1
Bit 2 - Set to 1
If yes, have you done this on your Q5? I have the VCDS, but need a bit more info on where/how the module installs.
Thanks
#12
spijun if I'm reading your post correctly, if you buy and install the Kufatec module and do the coding the hatch will open and close by either the remote or inside door button?
Thanks
Thanks
#13
Thanks
Thanks
Perhaps it would be best to contact the company Kufatec
I know when you buy their product they send you a link to download instructions on how to install
#14
Well, it's possible on the A7 using VCDS.
http://www.youtube.com/watch?v=6RCE_BghwN4
Plus, I found out how they're doing it so I will give it a shot.
Thanks for the responses. VERY HELPFUL.
Bit 2 - Set to 1
Bit 2 - Set to 1
If anyone with a Q5 has Electric Tailgate and wants to try it out, I'm game. I have regular meetups in the LA area, and occasionally in the Orange County,CA and San Fransisco, CA.
I am also having a meetup in Las Vegas, Nevada this weekend if anyone is interested. Details in my signature.
#16
I'm assuming the code above is only for the windows/moonroof; if so, I've already done it.
I have no issues if the module is really needed; just think it's dumb that you press the remote's lock or unlock button twice instead of the hatch button.
#17
Are you saying it works without the Kufatec module? I have the electric tailgate and a VAG COM cable. What code did you change?
I was saying that I would be willing to give it a try for the Q5 and this 3rd party hardware.
I will dig up the code I used and post it here.
#18
To make the Advanced Key Trunk Close function work, follow Stevial's instruction in the video.
http://www.youtube.com/watch?v=KIi0A...ature=youtu.be
In addition:
Select "(4)-Activation using rear lid opening function in remote key-Tap function for closing".
Store value will be "not active"
Select "active" in the New value drop down
Go Back, Close, Go Back, Exit.
Enjoy closing the trunk with your Advanced Key.
#20
Hello to Everyone I am new to this forum, I have retrofitted electric tailgate on a 2013 Audi Q5 also changed the 46 comfort module, have any one got the long coding for this function please?
Thanks
Regards
Roderick
Thanks
Regards
Roderick
