When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
I have the Audi optional 20x8.5 (offset 33) 5-arm design wheels on my 2014 Q5 TDI Premium Plus. Will the 19x8 (offset 39) 5-arm-star wheels fit on this car?
This is a photo of the 5-arm-star wheel
Spoken, thanks for providing the OEM wheel chart. The 19x8 OEM wheel is available with either a 39 or 27 offset. Do you know which of these offsets will fit the 2014 Q5 TDI ?
Both, because this is from Audi catalog depending on model rims
This is good news Spijun, since I have already purchased the Audi OEM wheels in the photo above. The size is 19 x 8 with a 39 offset. 8R0 601 025 BN. Thanks again for the information.
Spacers are rings that are installed between the hub and the rim. They modify offset and in effect help push a wheel further out, if needed.
Yeah...but do not use those...definitely do not use those!
If you're going to use them, get the "hubcentric" spacers.
They're the only ones I trust not to vibrate. They look like this and guaranty that the wheel stays perfectly centered on the hub.
