Whistle coming from right passenger window/mirror/door?
I noticed it after the car sat while we were on vacation for 2 weeks. It seems to whistle fairly loud at around 50+ MPH. I can't tell where it's coming from, but I think the mirror or door/window on the passenger side. I have rolled the window down and still hear it outside the car. Thoughts? Of course Audi couldn't "reproduce the customer's complaint". It's not constant, so it doesn't surprise me...could it be a seal?
I experienced the exact same thing last weekend. While driving on the highway the high pitched whistle was coming from somewhere around the passenger side window and putting the window up and down did not help. I drove the Q around town all week and when I hit the highway on Saturday it wasn't there. Not sure what it was but as general observation after owning my Q for 5000 kilometers, there seems to be a a host of intermittent rattles and other noises in this car. Hopefully it all settles down after more miles, but this vehicle has more noises than the Mercedes, and even a handful of Hondas I have owned.
Tea Anyone?
I have noted the same problem coming from mainly the driver's side window. Sounds like a tea kettle and is quite loud. It seems to have come up with the colder temperature. I have 9k on my Q5 and it just started. I figured out it comes from the seam between the mirror and the attachment to the a pillar (the mirror hinge) on the top and front edge. If I cover it with my finger, sound goes away, just annoying to drive that way when it's 50 degrees outside....Called dealer and they are fixing it next week. Offered me a loaner as well.
Hi all,
I had the same whistle noise issue on the driver's side window when driving at freeway speeds around 65 mph. Apparently, there is a TSB out for this issue (TSB2035673/1), which was applied for my Q5.
Basically, I was told that the space between the turn signal in the side view mirror and the actual mirror itself was causing the wind noise, as air flow at high speeds would get into this space and cause the whistle noise.
So Audi basically filled this space with "insulation" (a felt strip and foam), per the TSB.
After the fix, I test drove my Q5 on the LA Freeway where the whistle noise most often occurs, and I noticed that the fix worked! I'm still skeptical of what I think is a "band-aid" solution, so we will see how long this solution lasts.
Hope this helps!
Hope this helps!
gbmarc
03-29-2013 08:10 AM
BlueS4orce
06-24-2004 08:37 PM
heinz57
03-13-2000 06:07 AM
Will
01-28-2000 04:05 PM
