Will new Q5 'not' be a Torsen?
Check out this article which seems to indicate that new Q5 will not be Torsen. Sounds like a Haldex like system? Take it for what its worth... could be bogus.
New Audi quattro ultra four-wheel drive system detailed | Autocar
Sounds plausible. Audi needs to get the mpg of the fleet up and the Q5 is a high volume seller. Will need to see how this performs. I have an S3 and the quattro works great.
I thought that Audi had gone away from Torsen to a proprietary system some time back. But at least it is still steel gears all the way. I am sure they will make this new system work but I wish they would just leave the longitudinal engined cars alone and not introduce automated clutches and stuff. This new system is bound to have a lag spinning up the driveshaft so it will be lumpy like a Haldex system.
If the new system can produce fuel savings of 0.3l/100 km as the article suggests it will make a noticeable difference to AUDI's CAFE numbers in the future...and for them that is a good enough reason to do it. But I doubt whether any of us real humans will notice.
AudiWorld Expert
Audi all wheel drive explained | awd cars, 4x4 vehicles, 4wd trucks, 4motion, quattro, xDrive, SH-AWD, Haldex, Torsen, wiki - How it works
Keep in mind, Torsen has some weaknesses, too. In rare cases when a single axle loses grip completely (very low traction on ice) the car is not able to move because no torque is sensed on one of the axles, so the differential does not lock. Remember the BMW 'test' exposing this weakness?
Quattro Vs. Xdrive Test | awd cars, 4x4 vehicles, 4wd trucks, 4motion, quattro, xDrive, SH-AWD, Haldex, Torsen, wiki - How it works
Again, this is a fairly rare case, I would say. Torsen has worked pretty well in practice over the years, but I can see how the race to better fuel economy will make it go away.
This... If they want to disable an axle to save gas, then disable the front one and put a button to let me choose when I want to do it. I'm not paying "Q5 money" for AWD that feels like a RAV4.
Current Q5 still uses Torsen...
I share your sentiment. And the new system described in the article does sound more Haldex-like.
if you watch the BMW clip.. the key was that the driver was bumping the throttle instead of keeping it pressed down and letting ASC detect the wheelspin. Audi published a video that showed how to properly deal with the one axle on ice situation. Ill see if I can find that video.
Here is one of them....
Here is the other one...
Yup.. The Haldex system is sometimes called a 'slip and grip' where it runs in 2wd mode until slip is detected and then it brings on the other axle. the Torsen is putting torque to all four wheels all the time so slip is avoided... Id rather avoid slip than try to recover after it happens... Just my preference.
