Yet Another TDI Owner Saying Hello + Thoughts on the Competition
#11
#12
![EEK!](https://www.audiworld.com/forums/images/smilies/eek.gif)
In D it's a little slow off the line, but in S there's no hesitation at all. It seems like it's more of a programming thing where D is meant to be laid-back and S is meant to be sporty -- and both serve their functions well.
#13
AudiWorld Expert
#14
You get going quickly, and in D8 I went from 80 to 95 in a matter of seconds before I noticed while passing the other day.
So I'd say there's sufficient power here. ![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
#15
you sir have clearly never driven a modern diesel engine. go test drive one. anyone, even a jetta tdi. highway passing is where a diesel shines. in top gear on the highway the tdi will leave an SQ5 in the dust during top gear highway acceleration.
#17
Just need two nearby owners (one of each) to do some controlled runs to answer these burning questions that don't really matter in typical use cases.
#18
The TDI's torque should give it a jump on the S, but of course that (small) lead wouldn't last for long as the S has the top end taken care of.
In typical uses I fully expect the performance of most Q5s to be very similar and it's more down to other factors on what engine is "right" for you.
The more interesting question in my view is how different the Q5 TDI or SQ5 are from the S4/S5 in terms of handling and general driving experience. I love the S4/S5, but not the A6 3.0T, for example, even though the A6 has the same engine. I don't know if Audi has been able to replicated some or most of the S4/S5 experience in the SQ5, and it doesn't look like I can test drive the SQ5 or the Q5 TDI for that matter.
#19
AudiWorld Expert
I have a 3.0T right now and think that alone might be quicker (than my TDI) in this case.
Maybe I'll log both in the next few days in matching circumstances and compare...
EDIT: I overlooked the "top gear" part of the statement. Yes, in top gear (8th) with similar RPMs for each, it will put the TDI in it's wheelhouse for torque, which effectively dictates acceleration. I said the same thing in this thread here:
https://www.audiworld.com/forums/sho...php?p=24504521
#20
AudiWorld Expert
The TDI also has a small turbo, variable vanes, and a ton of torque at low RPM anyway. So it's turbo lag is very minimal compared to most anything else out there. And from a stop it's non-existent. 1st gear is geared so low, it's gone in an instant, not even enough time for boost to get to a steady point. It's a blast
