Q5/SQ5 MKII Discussion Discussion forum for the Second Generation Audi Q5 SUV
2018 Q5 rear Coil Spring broke
Old 08-17-2023, 05:59 AM
sesteynh's Avatar
Default 2018 Q5 rear Coil Spring broke
Hi
I have 80,000 service on my 2018 Q5. They have indicated that one of the rear springs is cracked and needs replacement. I don't do any offroad driving. Has anyone else had this issue occur? Is it covered by warranty. They also want me to get a 4 wheel alignment after replacing the spring. Any advice or feedback would be welcome
scott
Old 08-17-2023, 07:32 AM
jim2560's Avatar
https://www.audiworld.com/forums/q5-...pring-3040425/
Old 08-19-2023, 09:43 AM
blchandl2's Avatar
This is also being reported on the BMW forums. I wonder if they use the same supplier?
Old 08-21-2023, 12:08 PM
packardv8's Avatar
Yet another systemic failure on carefully maintained low-mileage Audis and VW Group dodges responsibility for a safety-related fix. Makes it really, really difficult to give a positive response to "Ask the man who owns one."
jack vines
Wires (08-21-2023)
Old 08-22-2023, 08:40 AM
rdA4WtQ5's Avatar
Only 2018's from what I have seen. Anyone with other years having failed springs?
Old 08-22-2023, 08:53 AM
packardv8's Avatar
If coil spring failure is 2018-only, all the more reason a recall and repair should have been already instituted. If earlier models aren't failing, then Audi changed suppliers or specification. No excuse for not stepping up on a safety issue.
jack vines
Old 08-22-2023, 09:42 AM
rennen-affe's Avatar
2018 here. No failed spring.
Y'all make it sound like all 2018's. Will bite tongue if it happens here.
Old 05-01-2024, 05:03 PM
Wires's Avatar
Noticed my 2018 SQ5 had that when checking today. (49k miles / 78k km). Passenger side spring is broken at the mount.
Old 05-01-2024, 08:15 PM
AudiAllTheWay's Avatar
Folks should post pics of the broken springs so we can see more detail.
Cold climate salted road environment will cause springs to break over time on any vehicle. Once the finish on the spring is cracked then it is the beginning of the end as corrosion sets in and the spring will break.
Old 05-01-2024, 08:22 PM
That's not from corrosion
blchandl2 (05-02-2024)
Quick Reply: 2018 Q5 rear Coil Spring broke
