Q5/SQ5 MKII Discussion Discussion forum for the Second Generation Audi Q5 SUV
2019 Sq5 Audi Connect Issues
Old 06-12-2019, 06:10 PM
Alex Wong's Avatar
Default 2019 Sq5 Audi Connect Issues
Hi all
Just picked up my SQ5 a couple of days ago. Audi connect is set up and works when the car is on and up to a couple minutes after turning the car off. Once a couple minutes go by the data connection to the car seems to turn off and no information doesn't get pushed to the app.
Had a good search through and didn't see anything. Has anyone else run in to this?
Thanks in advance!
Alex
Old 06-14-2019, 03:40 PM
Alex Wong's Avatar
Originally Posted by Alex Wong
Hi all
Thanks in advance!
Alex
No one else having this issue? Dealer seems to have no O'Dea
Old 06-14-2019, 05:55 PM
2018 Audi SQ5 Prestige
UK_Wildcats_Fans's Avatar
How are you testing? I have a 2018 8 SQ5 Prestige with Audi Connect. My dashcam connects to the car wifi without any issues. Also I have no problems with the My Audi app, which replaced the Audi Connect app.
Old 06-14-2019, 05:59 PM
Alex Wong's Avatar
Thanks for the reply!
I am using the my audi app. Once the car has been off for a couple minutes, the data turns off and connection to the my audi app is gone. Can't lock / unlock the car and can't update the car stats.
I tried a factory reset, turning on and off the privacy, logging out and in to the audi connect account. No luck
Old 06-15-2019, 03:26 AM
1sato's Avatar
I've experienced many problems with Audi Connect -- often receive "Vehicle cannot be reached" error regardless of where car is located and with strong signal. I've referred issue to Audi but they're unable to correct.
Old 06-15-2019, 03:36 PM
Markster's Avatar
Same issue with 2018 S4. Both dealer and Canada Audi unable to get it fixed. The iOS app is working but if I try using car MMI and connect 99% of the time I get a message unable to connect to the server. Even if I manage to connect when trying to login with MMI get a message that cannot connect. Nobody at Audi knows and this is troubling.
Old 06-16-2019, 07:25 AM
Alex Wong's Avatar
Interesting. A dealer from a Canadian website noted that there is a software fix. I sent this to my dealer and they're going to get back to me. Will provide an update when I hear back.
Old 06-16-2019, 08:24 AM
Markster's Avatar
Thank. Yes please get back to me. Can you share the text from the dealer and the fix notes ?
Old 06-17-2019, 07:11 AM
JeffreyTT's Avatar
It's $35 for a day's access, ot $60 for three days, but Audi's online service site has the service guides, TSB's, training, and other dealer notices. Most everything is PDF, so with a little time you can get everything downloaded including the extensive service manuals. If this is a known issue, you'll find it here.
https://erwin.audiusa.com/erwin/showHome.do
Jeff
Old 10-28-2019, 05:57 AM
Thierry Eppner's Avatar
Hello,
I have the exact same issue with my brand new Audi Q3 45 TFSI.
Did you manage to solve this issue ?
There was an MMI update solving this ?
Thank you
Regards
Thierry
Quick Reply: 2019 Sq5 Audi Connect Issues
