How do I set ALA to intervene as early as possible
I used OBDEleven to activate on Active Lane Assistance. How do I set it to intervene as early as possible? I found an app that says deactivate early or late and thought that was how you wanted the ALA to deactivate not activate so I have that set on late
You want it to early. That will do a better job of centering the vehicle in the lane. If you set it to late, it won't correct until you get to/cross a line.
There was something to be said for my prior Lexus, which had no driver assistance features, and where the lane assist had one purpose, to keep you from veering into another lane. There was no effort to steer, or keep you centered. If you started to drift, the wheel would vibrate and maybe (I don't recall) tug you back a bit. The Audi is definitely a bit of a different feel, with the feel of the tugging while simply driving normally, and the ALA trying to keep you centered. YMMV, and like I said, it can be tailored somewhat to your preference. I recall that I made some further customization to the ALA with OBDEleven.
In the MMI drivers assistance setting I have "early" selected. My question is in regard to the OBD one click app that says "deactivate" lane assist so I clicked "late" on that one...Am I suppose to click "early" on that one in the OBD app as well???
Not sure about that one. I'd assume if you picked "deactivate" in the app, then it never comes on? Was there an activate and deactiveate app in OBDEleven to setup? Mine was shipped with ALA, so I change the settings through the MMI.
All I know is "late" corrects steering once you crossed the line (that big brother is checking out for you type thing), whereas "early" gets you "autonomous steering" (as best as it's offered on this platform). Keep in mind how well it works depends on how defined the lane markings are, and if the forward facing windshield camera is clear (and does not have full sunshine right into it).
Ahhh.. I gotcha. Yes, it's probably the notification if you aren't touching the wheel. From my testing, changing that does nothing. Audi seems to have it set to around 12-14 second.
I don't think it's adjustable on the B9 platform. There are settings you can tweak with OBDEleven, but they are just "red herrings" that do nothing.
woods4
01-24-2008 10:53 AM
