Long Crank (hey now...)???
Has anyone else noticed their car taking significantly longer to turn over with age/mileage?
When the car was new, regardless of how long my car had been sitting, it typically fired immediately, however I've now noticed that the car cranks for roughly 4 seconds before firing. If it has been driven within an hour or two of restarting, there's no, or very little issue.
I'd like to say it's weather related, however it's been occurring since late summer.
I'm typically oblivious to things like this, however it's now become apparent.
Interestingly, my former BMW had the same issue, and they replaced my high pressure fuel pump, under warranty, which eliminated the issue altogether.
Normal behavior? I don't believe it warrants a trip to the dealer just yet, especially if others are experiencing similar behavior.
2018 SQ5 - 17k miles
In order:
1. Scan for codes. Any fuel pump issues should show up. If all clear then:
2. If you haven't done so already use a strong dose of Techron. Can't hurt.
3. Kind of soon for spark plugs unless mainly short trips. Tired higher mileage spark plugs do behave like this.
Thanks rd, appreciate the reply...
If it persists, I'll have the dealer do a scan (I don't have a reader).
I'll report back on whether or not the situation worsens...
Low battery can cause it as well. Otherwise I'd say this isn't normal.
With such low revs when driving, charging is quite restricted on all vehicles. My commute is 17 minutes on the highway everyday. I left home in my 340, drove to work and it puked the "battery discharged, start your engine" warning (we had left the car for 10 days when on holidays). Did that morning and night until I hooked the battery charger to it for the weekend. If your commute has a lot of short trips, and engine start/stops, the discharging gets compounded. With my 340, that's when it started doing the "dreaded long crank". Once the battery was fully charged, it was fine.
Other things that can cause issues is it struggling to sync the motor spinning over. You should get a code for that though.
All vehicles are the same. If you deplete it too far, you need to take a pretty decent drive to bring it up to capacity. At idle/low RPM the alternators just don't put out the power.
Highway driving usually means 2k rpm cruising, I drive 6 miles of mostly city style streets in a lot of waiting at lights idling and still don't have the issue
