No drill front license plate
What are my options to install a front license plate without having to grill it in? I live in Washington, where front license plate is mandatory. I recently places an order for a Q5 and I am debating if I should have the front plates removed. I really do not like the tow hook option. Is there anything else I can do?
SYMAWD is correct.
Get these: 80A-853-441-E-3Q7
https://www.audionlineparts.com/oe-audi/80a853441e3q7
Basically, when you remove the front plate holder bracket, the screws align INSIDE the trim on the SQ5 (NOT SAME pieces on Q5. It appears they have a D ver, not the E used in my SQ - see link below). You then just snap in the trim strip to cover. Easy peasy.
You don't have to replace the entire bar like I did in my 14 Q5.
You can see where I snapped in the top bar already. Literally like 45sec to clean up the front.
https://www.audiworld.com/forums/q5-.../#post25037603
SYMAWD is correct.
Basically, when you remove the front plate holder bracket, the screws align INSIDE the trim on the SQ5 (probably same on a Q5...). You then just snap in the trim strip to cover. Easy peasy.
thanks for the answer and link!
Woudnt it be easier to stick a sticker licence plate? something like this Custom License Plates - Adhesive license plate replica
