OBDEleven scan results
OK, this is a new guy question... I tried searching forums for some insight but I’m clearly not searching the right terms.
Just bought a CPO Q5. (First Audi ever...)
I also bought an OBDEleven from DAP so I could read codes to monitor the health of my new ride and maybe even take a whack at enabling active lane assist once I got familiar with the unit.
So this morning I run my first scan on the car (that I’ve only driven 800 miles since delivery)and it throws out 6 faults! All of them listed intermittent.
Brakes-Right Rear Tire-Tire Pressure Warning-flat tire Fault code C105B00-intermittent
Brakes-Multi Axis Acceleration Sensor Module “A” Fault code C052000-Intermittent
Air Conditioning Heated Left Rear Seat Electrical Error Fault Code B111701-Intermittent
Gateway-Energey management active Fault Code U140B00-Intermittent
Comfort System-Databus missing message Fault Code U112100 Intermittent
Telematics-Control Module incorrectly coded Fault Code U101400-Intermittent
Also, the when I click on the “Garage” icon in the iOS app (I have an android phone arriving tomorrow that will get dedicated to the OBDEleven...)
Under Faulty CU it lists:
Faulty CU
Control Unit
03 Brakes
Passive Faults
Under Full Scan it shows 30 control units with a fault count of 6 (they’re listed above)
Should I reset these and see if they return? And should I be a little alarmed that a vehicle which supposedly just went through a 300 point CPO inspection should show so many faults?
On a more humorous note, it also freaked me out initially when the OBDEleven showed a mileage of 10744–until I figured out it was showing me kilometers while I live in a mile country...
Faulty CU
Control Unit
03 Brakes
Passive Faults
Take my input with a grain of sand as I'm not a mechanic or expert. That said, this seems pretty normal. Intermittent errors show up regularly. Anytime there is a communications glitch of any sort, these show up. If you are not getting any Virtual Cockpit messages, I wouldn't be concerned.
Your plan to clear and watch if they come back is a good one in my opinion. Before you clear the errors, email the results of a scan to yourself so you have record of it. There's lots you can do with the OBDEleven. Search this forum - lots of coding examples. Even if they come back, it doesn't mean there is a problem.
I had major glitches at one point that did show up on the VC. Sent a scan to the dealer. Then visited the dealer. They basically said unless it is a current problem (still happening), the codes won't mean much because stuff (communications glitches) happen.
You think that's bad, I bought my Q5 new, had like 14 miles on it, and it had around 11 faults first time I scanned it with OBD11. I cleared them all and most have never come back. I still continue to get a Databus Missing Message error, Control module incorrectly coded, and something about emergency call module intermittent error. Oh well.
Since everything communicates on the CAN bus, power glitches, etc can cause spurious faults. If they are substantial, they will trigger the CEL until cleared.
Mine has a ton as well, so I wouldn't loose any sleep over it.
First, thanks for all the replies. The explanations I’ve heard from you all make sense. I’ve cleared the codes and will see if they reappear, I guess if there is an accompanying malfunction with the vehicle it will point me (or, um, my mechanic...)in the right direction.
I think I’d like to have the doors auto lock when the doors are closed and key fob outside the vehicle—after a period of time. I’m not sure I if the delay is easily programmable though. Also, I’d like to turn on the active lane assist or at least a lane departure warning. I understand that my model (2019 Premium Plus) has all the hardware already installed as part of the “pre sense city”
I've driven a car w/ Active Lane Assist and didn't like it at all. It had a "Big Brother is Watching You" vibe. Too creepy. A rental Kia. No desire to turn that one, available or not. To each his own.
George Trudeau
Q7 MK 1 Discussion
11-18-2018 11:00 AM
