Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Do I really need PREMIUM gas in my Q7?
Old 06-23-2006, 03:46 PM
New Member
rileys's Avatar
Default Do I really need PREMIUM gas in my Q7?
I'd like to hear from you folks as to what kind of gas you are puting your Q7s. I have heard from some mecanics that today's cars don't need premium unless you notice knock. I ran regular in my 05 4.2 Allroad and never noticed any problems. However my wife insists on at least mid-grade octane in her A4 3.0 Cab.
What about it? Does it really matter?
Old 06-23-2006, 06:16 PM
New Member
BlueWorld's Avatar
Default Re: Do I really need PREMIUM gas in my Q7?
Your engine is smart enough that it will de-tune itself so it will not knock even with an 87. However, your engine will be so de-tuned that you will be significantly less fuel effiecient than if you ran the proper octance. You won't be saving any money, and you'll have worse performance to boot.
E.T.Human Hybrid (07-31-2023)
Old 06-24-2006, 09:27 AM
Member
Krisko's Avatar
Default I think you're wrong on the fuel economy.
I've run regular gas for 6 months now in my Touareg (same engine as Q) and have an identical mpg. The performance loss is significant however and it doesn't magically come back with a fresh tankful of 93.
The Q is completely fine running regular gas but you will feel a little sluggish off the line.
Old 06-24-2006, 12:18 PM
New Member
BlueWorld's Avatar
That just means you were running crappy gas.
Old 06-24-2006, 02:26 PM
New Member
JDoe62's Avatar
Default Touareg and Q7 not the same engines
Q7 and Touareg engines are NOT the same. The VW has a 4.2 liter V8 and the Q7 is a 4.2 liter FSI V8.
Old 06-24-2006, 06:25 PM
der Scherzkeks's Avatar
Default Re: No, but you paid for those ponies.
I've never understood this.
Why do people turn into tightwads at the pump when they don't think twice about supersizing their happy meal or changing their tall into a venti?
Old 06-25-2006, 04:39 AM
Member
Krisko's Avatar
True but I'm sure the engine will run fine on 87.
Old 06-27-2006, 09:58 AM
paulroad's Avatar
Default basic rules of Audi...
put in cheaper lower octane gas you will get less MPG and lower performance. Put in what is suggested --91 oct. and you will get the performance you want and the MPG will improve as well. So with better MPG from higher oct. you are not spending any more $$
Old 10-19-2018, 02:08 PM
anilt2k's Avatar
Default What is the mpg difference?
We are talking here milage different between 87 Vs 92 Oct... how much it improves a mile or two? I am sure not 5 or 10 miles, isn't it!
Old 10-19-2018, 07:58 PM
cuatrokoop's Avatar
This was an old post...
Also, when running less than recommended octane (in any vehicle), you need to keep driving style in mind. If you tow, run premium, the ECM won't work so hard pulling timing and minimizing knock and your engine will thank you. If you have a heavy right foot, run premium, the ECM won't work so hard pulling timing and minimizing knock and your engine will thank you. If you putt along at the speed limit and dawdle while getting up to speed, run 87 or 89. If you have a Stage 1 or higher ECM map loaded up, you better run premium, or you may get a CEL glowing on the dash.
Quick Reply: Do I really need PREMIUM gas in my Q7?
