Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
■Emergency!!■ about Headlight Range Control Defective
Old 12-17-2018, 08:25 AM
JasonByeon's Avatar
Default ■Emergency!!■ about Headlight Range Control Defective
Hi all
i really needs help about "Headlight Range Control Defective" warning light and actually headlight range control doesn't work
i have vagcom so i've ran and tried everything but still not working....
01535 - Control Circuit for Right Headlight Range Adjusting Motor
so. let me tell you what happened before that showed up.
i have ordered OEM headlight ballast for my audi q7 3.0TDI and i've just replaced it without any problem.
i've plugged power into the right headlight and i forgot to plug the left headlight power and i turned on car.
and that error showed up so i've shut off the car and plugged right side headlight power.
when i turned car on, the headlight always been up and down but this time it didn't work with that fault code up
i have reset everything from vagcom and still not working.
I am thinking put the original ballast back and try it again
plzzz help me out !! it is so emergency
I have to go back to the army base in a day so i don't have lots of time to figure the problem out
thanks all for help
Old 12-17-2018, 08:33 AM
Built4Sin's Avatar
You cleared the faults and its still, popping up a fault?
Audi Q7 (4L) - Ross-Tech Wiki
Audi A6 (4F) Headlight Aim Control (Adaptive Light) - Ross-Tech Wiki
Old 12-17-2018, 08:55 AM
JASON BYEON's Avatar
Default Yes it still shows up
Originally Posted by Built4Sin
So i just removed new ballast and then i replaces original ballast and headlight range control still not working it aim down from first
Old 12-17-2018, 09:48 AM
Built4Sin's Avatar
You need to click the link I posted, and follow the headlight adaptation (Aiming) procedure.
Basic Setting
Headlight Adjustment
[Select]
[55 - Xenon Range]
[Basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
  • The meas. block field now shows "Wait" and should switch to "Adjust Headlights" then (this may take up to 10 seconds).
  • Adjust the headlights using their manual adjusting screws as referenced against a suitable aiming target.
[ON/OFF/Next]
The adjustment should now be learned.
[Done, Go Back]
Don't forget to check/clear fault codes afterwards.
[Close Controller, Go Back - 06]
Old 12-17-2018, 10:23 AM
JasonByeon's Avatar
Default Wel....l
Basic Setting
[Select]
[55 - Xenon Range]
Group 001
[Go!]
[ON/OFF/Next]
[ON/OFF/Next]
[Done, Go Back]
Hmmm well mine is 08 Q7 so may not have many options than other years and vcds 15.7.1 is what i have it here
Old 12-17-2018, 10:55 AM
Built4Sin's Avatar
Did that get your headlight to re-align?
Old 12-17-2018, 11:03 AM
JasonByeon's Avatar
nahhh that didn't do anything actually nothing i could do on that page
Old 12-17-2018, 11:27 AM
Built4Sin's Avatar
Try this one:
https://www.audizine.com/forum/showt...non-Headlights
Its going to be that sort of procedure that will clear your error. That comes from this thread:
https://www.audiworld.com/forums/q7-...g-com-2906845/
veiks20
A4 (B8 Platform) Discussion
09-02-2018 04:49 PM
jrc1966
10-01-2017 01:46 PM
Limitsbreak
04-04-2014 02:21 PM
DRV HRD
11-22-2007 08:56 AM
mroberts
07-25-2003 08:59 PM
Quick Reply: ■Emergency!!■ about Headlight Range Control Defective
