08 Q7 WET CARPET- help
#11
My Q7 had a wet driver side floor after rains as well. It was the sunroof....But the drains were not clogged. the nipple that plugs onto the sunroof...well where the nipple glues to the tubing...it broke free. The glue looked like it never did adhere. So I check the the other three...
And sure enough, on the other three, the glue was about ready to let go. I was soon to have all four drain tube nipples break free from the tubing. Nice design Audi!
I ended up putting some brass tubing inside the rubber tubing and then used a wire tie to secure the nipple back to the tubing. I also used just a little bit of silicone. Now the nipple thingys are attached to the tubing solidly.
So, if your getting water inside, it could be that your tubing separated from the nipple thing that plugs onto the sunroof drain. the glue on all four of mine was breaking free...one was completely detached because the glue failed.
#14
#15
Where did this image come from ? is there a specific repair manual you use or you could recommend that would have this kind of information for everything regarding the Q7 ?
Costasz
08-30-2010 03:32 PM
Audi_kraut
08-03-2003 11:05 AM
