2007 Audi Q7 Bose Amp removal/location VIDEO as promised
As promised I have created a video on how to remove and locate the Bose Amp.
I have also created a DIY guide, just search for Audi Q7 Bose Amp Removal.
Hope this Video is useful, I will be posting more Videos and DIYs in the near future.
Thanks for looking
Video link
CMG Video
Thanks for looking
Video link
CMG Video
Great video of Bose Amp removal for Audi Q7. You showed all clips securing points torx T25 and T30 as well as all connector blocks on rear access panels. I hope I got all the keywords in again
It is a pity you did not show us where the water was getting into the amp from. I know it is caused by blocked rear sunroof drains overflowing through their vent pipes into the car but I have never seen the actual route and if there is a simple solution to diverting it away from the amp or its wiring loom. There are other modules in hte same location that can suffer in a similar fashion such as the Bluetooth modeule, Suspension module.
Part number for MOST Bridge connector (referred to here as Fibre Optic Loop) 4E0 973 802 Available from Kufatec.
Part number for Bose Amp 4L0 035 223A
Hopefully if the weather is good this weekend I will post a new video and instructions on how to remove roof liner and replace the 4 drain plugs, weather permitting that is. So check back on Monday
Cheers and glad I could help.
I was already installed in the car when I purchased it.
Keep a look out for other videos, hopefully by the end of the week I will be able to post the roof liner removal and sunroof drain plugs DIY.
cheers mate.
cheers mate.
EvotechTT
SoCal Discussion
03-14-2006 11:45 AM
Merou
06-05-2002 04:11 AM
