2008 q7 and just got a vag com to code...
Just purchased a vag com from Ross Tech....awesome little unit however, I am having a heck of a time trying to find info on my year of car. Mine is a 2008 with the 4.2. I wanted to do the needle sweep BUT the screen that appears is yellow and there is no option to change anything. Anyone have other mods that will work for a 2008? Maybe an early year production 2008 and it uses the system from a 2007??
Thanks for any input and codes to help get this beast a bit modded.
Cheers.
Cheers.
There's tons of stuff to do, first thing you needa do tho is a full scan of all modules and save the results to a file.. If you ****up any coding this file will contain all the original codes.
Is there anything specific your wanting to do? If not just go throughout the modules, open the long coding helper and see what coding tweaks you can make for starters.. There's other stuff that can be done through adaptations but you typically need documentation to help you through that.
do you have a real ross tech device or a knockoff? If its a knockoff, VCDS is just a demo and you can only look and clear codes, thats it.
Try some of these and see if you get anywhere: http://www.audienthusiasts.com/VagCom.html
Try some of these and see if you get anywhere: AudiEnthusiasts Vag Com
