2013 Q7 prestige s line code 01435
Hi im new here and a new Audi owner. Ive never owned an european car but have always been a gear head and tuner but now im on a new learning curve. 2 weeks after getting this 2013 Q7 s line I get a 01435 code periodically and now it won't clear. Scaner shows brake pressure sensor responding with 9.3 psi idle and 2000 psi with brake pedal depressed. Im getting a traction control light and toms. The abs u1017 would clear but 01435 wouldn't. Any ideas?
VIN: WA1DGAFE4DD011520
Car: Audi Q7
Year: 2013
Body type: SUV
Engine: CTWA 245 kW (333 HP) 3 l
Mileage: 139520 KM
01 Engine
System description: 3.0l V6 TFSI
Software number: 4L0910551Q
Software version: 0020
Hardware number: 4L0907551A
Long coding: 0121000A290F0128
Trouble codes:
U1017 - ABS brake control module Read out DTC
static
02 Transmission
System description: AL1000 AISIN
Software number: 0C8927750Q
Software version: 2090
Hardware number: 0C8927750Q
Hardware version: 002
Serial number:
ODX name: EV_TCMAL991031
ODX version: 002112
Long coding: 001378
Trouble codes:
No trouble codes found
03 Brakes
System description: ESP ALLRAD MK25E1
Software number: 4L0910517M
Hardware number: 4L0614517L
Coding: 0099409
Trouble codes:
01435 - Brake pressure sensor 1 Electrical malfunction in circuit
static
04 Steering Angle Sender
05 Kessy
System description: FBSAUDIC6 ELV H08
Software number: 4F0910852B
Software version: 0200
Hardware number: 4F0905852H
Hardware version: 242
Serial number: 10603702040393
Coding: 0000135
Subsystems:
System description: FBSAUDIC6 EZS H04
Software number: 4F0910132L
System description: FBSAUDIC6 KSG H03
Software number: 4F0910335B
Trouble codes:
00191 - Front passenger exterior door handle touch sensor Short circuit to ground
static
00193 - Right rear exterior door handle touch sensor Short circuit to ground
static
08 Air Conditioning
System description: KLIMA 4 ZONEN
Software number: 4L0910043D
Software version: 0070
Hardware number: 4L0820043AQ
Hardware version: H15
Serial number: 00000000360192
Long coding: 000AC026
Subsystems:
System description: SLR-B8
Software number: 8K0959772F
Software version: 0007
Hardware version: H06
Serial number: 0079179973
Long coding: 070000
Serial number: 0079180266
Long coding: 070000
Trouble codes:
09 Central Electrics
System description: ILM Fahrer H31
Software number: 4F0910279AG
Software version: 0400
Hardware number: 4F0907279C
Serial number: 4F0907279
Coding: 0133123
Subsystems:
System description: Wischer AU716 H18
Software number: 4L1910113
Software version: 0110
Coding: 0064792
System description: REGENLICHTSENSORH04
Software number: 8K0910557
Software version: 0003
Coding: 0150059
Trouble codes:
10 Parking Assistance 2
System description: PARKHILFE 8K
Software number: 4L0919475A
Software version: 0011
Hardware number: 4H0919475C
Hardware version: H07
Serial number: 55961302200063
ODX name: EV_EPHVA18AU7160000
ODX version: 001001
Long coding: 24011F
Trouble codes:
15 Airbag
System description: 73 AIRBAG AUDI8RH44
Software number: 4L0910655A
Software version: 0230
Hardware number: 4L0959655B
Serial number: 0038QD0C18G1
Coding: 0014131
Subsystems:
System description: BF-Gewichtsens. H05
Software number: 4L0959339C
Software version: 0040
Trouble codes:
16 Steering Column Electronics
System description: J0527
Software number: 4F0910549B
Software version: 0830
Hardware number: 4F0953549E
Serial number: 90026122790231
Coding: 0012142
Subsystems:
System description: E0221 H03
Software number: XXXXXXXXXXX
Trouble codes:
17 Dash Board
System description: KOMBIINSTR.
Software number: 4L0920985S
Software version: 0317
Hardware number: 4L0920985S
Hardware version: H35
Serial number: VJ3513Y1E
Long coding: 8BD663040900CF05020205
Trouble codes:
19 Gateway
System description: GW-BEM 5CAN-M
Software number: 4F0907468S
Software version: 0058
Hardware number: 4F0907468G
Serial number: 3700M131148003
Long coding: 00C303
Subsystems:
System description: J367-BDM
Software number: 8K0915181D
Software version: 0125
Serial number: 00000000004120112738
Trouble codes:
02256 - Static current Upper limit exceeded
static
03041 - Energy management active
Intermittent
00470 - Combination comfort databus in single wire Open circuit
Intermittent
28 Climate Control Unit Rear
System description: KLIMABETAETIGUNGH06
Software number: 4L0910158
Software version: 0060
Hardware number: 4L0919158AD
Serial number: 00000000359155
Coding: 0000006
Trouble codes:
36 Seat Adjustment Driver Side
System description: MEM-FS
Software number: 4F0959760D
Software version: 0064
Hardware number: 4F0959760D
Hardware version: H08
Serial number: 00000078974602
Long coding: 00581B00000011110000
Trouble codes:
3C Lane Change Assistant
System description: J0769_SWA_MasterH02
Software number: 4L0910566C
Software version: 0050
Hardware number: 4L0907566B
Serial number: 6PZ 009 014-10
Coding: 0000001
Subsystems:
System description: J0770_SWA_Slave_H02
Software number: 4L0910568C
Trouble codes:
42 Door Electronics Driver Side
System description: TSG FA
Software number: 4F0959793T
Software version: 0362
Hardware number: 8K0959793M
Hardware version: H12
Serial number: 0000050577846
Long coding: 011F57205E40440004
Trouble codes:
01705 - Mirror selector switch Implausible signal
Intermittent
46 Central Module Comfort System
System description: Komfortgeraet H12
Software number: 4L0910289K
Software version: 0130
Hardware number: 4L0907289K
Serial number: 01903872940000
Coding: 3569949
Subsystems:
System description: LIN BACKUP HORN H05
Software number: 1K0951605C
Software version: 1501
Trouble codes:
03073 - Rear lid -closed- sensor Implausible signal
static
47 Sound System
System description: BOSE G3 Q7
Software number: 4L0035223J
Software version: 0160
Hardware number: 4L0035223G
Hardware version: H04
Serial number: 00000000012659
Long coding: 030000
Trouble codes:
4C Tire Pressure Monitoring 2
System description: J793 RKA+ H04
Software number: 4F0910274B
Hardware number: 4F0907274
Serial number: 00005190071029
Coding: 0693965
Trouble codes:
01316 - Brake control module Please read DTC
static
4F Central Electrics 2
System description: ILM Beifahrer H16
Software number: 4F0910280
Software version: 0100
Hardware number: 4F0907280D
Hardware version: ---
Serial number: 00000000131461
Coding: 0012001
Trouble codes:
52 Door Electronics Passenger Side
System description: TSG BF
Software number: 4F0959792T
Hardware number: 8K0959792M
Serial number: 0000050594563
Trouble codes:
55 Headlight Regulation
System description: AFS 1 H01
Software number: 4L0910357B
Software version: 0010
Hardware number: 4L0907357B
Coding: 0000031
Subsystems:
System description: AFS-Modul links H07
Software number: 7L6941329A
Software version: 0004
System description: AFS-Modul rechtsH07
Trouble codes:
56 Radio
System description: Radio U SIRIU
Software number: 4G0035082E
Software version: 0121
Hardware number: 4G0035082
Hardware version: H60
Serial number: 156A%0D7684708
Long coding: 020007010000000000
Trouble codes:
5F Information Control Unit
System description: H-BNT-NA
Software number: 4L2035746C
Software version: 0624
Hardware number: 4L2035746A
Hardware version: H44
Serial number: 224AV0D7517184
Long coding: 180200060004E1EF510003456F632003140000000100000000
Subsystems:
System description: NAR 2013
Software number: 8R0060884BA
Software version: 0703
System description: DU7 High
Software number: 8R0919604A
Software version: 0104
Hardware version: H42
Serial number: A130AG0D2643511
System description: E0380 Bedient
Software number: 4L0919614C
Hardware version: H01
Serial number: 00000002050903
System description: CD-Database
Software number: 8R0060961E
Software version: 4949
Trouble codes:
62 Door Electronics Rear Left
System description: TSG HL
Software number: 4F0959795P
Hardware number: 4F0959795P
Hardware version: H11
Serial number: 0000050608020
Long coding: 010E57204040230004
Trouble codes:
6C Camera System Rear View
System description: J772__Rearview
Software number: 4L0910441B
Software version: 0030
Hardware number: 4L0907441B
Serial number: 525PA8-J2Z40NB
Coding: 1021201
Trouble codes:
6D Deck Lid Control Unit
System description: ValeoHeckdeckel H57
Software number: 4L0910945
Software version: 0500
Hardware number: 4L0827851E
Hardware version: H57
Serial number: E5030000B
Subsystems:
Software number: 4L0910946
Trouble codes:
6F Central Module Comfort System 2
System description: ILM HINTEN 2 H08
Software number: 4L0910290A
Software version: 0080
Hardware number: 4L0907290A
Serial number: 129560435-----
Coding: 0003595
Subsystems:
System description: J_245_EE16_SKB10H13
Software number: 4L0910591A
Software version: 0220
System description: J_394_EE16_SKB10H13
System description: J_392_EE16_SKB10H13
Trouble codes:
72 Door Electronics Rear Right
System description: TSG HR
Serial number: 0000050608024
Trouble codes:
02126 - Central locking button, exterior door handle Implausible signal
static
Car: Audi Q7
Year: 2013
Body type: SUV
Mileage: 139520 KM
01 Engine
Trouble codes:
static
02 Transmission
Serial number:
ODX version: 002112
Long coding: 001378
Trouble codes:
03 Brakes
Coding: 0099409
Trouble codes:
static
05 Kessy
Coding: 0000135
Subsystems:
Trouble codes:
static
static
08 Air Conditioning
Subsystems:
Long coding: 070000
Long coding: 070000
Trouble codes:
Coding: 0133123
Subsystems:
Coding: 0064792
Coding: 0150059
Trouble codes:
ODX version: 001001
Long coding: 24011F
Trouble codes:
15 Airbag
Coding: 0014131
Subsystems:
Trouble codes:
Coding: 0012142
Subsystems:
Trouble codes:
17 Dash Board
Trouble codes:
19 Gateway
Long coding: 00C303
Subsystems:
Trouble codes:
static
Intermittent
Intermittent
Coding: 0000006
Trouble codes:
Trouble codes:
Coding: 0000001
Subsystems:
Trouble codes:
Trouble codes:
Intermittent
Coding: 3569949
Subsystems:
Trouble codes:
static
47 Sound System
Long coding: 030000
Trouble codes:
Coding: 0693965
Trouble codes:
static
Coding: 0012001
Trouble codes:
Trouble codes:
Coding: 0000031
Subsystems:
Trouble codes:
56 Radio
Trouble codes:
Subsystems:
Trouble codes:
Trouble codes:
Coding: 1021201
Trouble codes:
Subsystems:
Trouble codes:
Coding: 0003595
Subsystems:
Trouble codes:
Trouble codes:
static
The_Jerbel (Jordan)
07-04-2007 04:03 PM
hillroad
VAG-COM Discussion
07-05-2006 09:02 AM
SupraTL
02-24-2006 01:16 PM
araudi47
09-20-2005 10:29 AM
