2014 Q7 3.0 TFSI Hesitation Issue
#11
I have a new 2013 Q7 3.0 (not TDI) and it is in the dealer right now for the same problem. From a stop and pressing the gas pedal a delay of 3 seconds especially on a stop and go situation. It is randomly and the dealer cannot replicate the fault. I recommended the brake sensor from the post below. I will found out later today the outcome.
#12
#14
Not the same issue.
The throttle is backed off simply because it detects that the brake pedal is being pressed - it simple logic - if you are braking then you cannot be accelerating at the same time, so the throttle is backed off, even if you have your foot on the floor.
The fault here is that it sounds like the brake pedal switch is faulty causing the ECU to think you are pressing the brake pedal so it backs off the throttle.
Exactly what some Toyota's did not do!
#15
That seems right. If you drive the Q7 on a beach, you can't completely turn off the ESP. It senses wheels spinning in sand, then activates the brakes to slow the spinning wheel. Then it senses the brakes overheating and cuts the power to that wheel. Then you lose momentum, get stuck and wait for the brakes to cool. (After a couple of these events, we went out and bought an LR3 for beach driving and kept the Q7 on pavement)
One of your brake heat sensors must have been bad and power was being cut. Hopefully it is now fixed.
#16
I suspect it is an assumption based on some rather poor explanation at some point. I don't think there is any form of brake temperature sensing, it is probably based on a calculated brake temp based on the duty cycle of the ESP and ABS etc... - knowing Audi, it will possibly also take ambient temp into account as well, maybe even barometric as well!
#17
I had the same issue with my 2012 Q7. Had everything checked per the other recommendations on this blog. They all checked fine. But, there is a part called the “ throttle body” which regulates the air into the engine. It’s both electrical and mechanical. Mine showed sporadic response on the computer. Mine had carbon buildup and didn’t open/ close correctly. We replaced it and it’s infinitely better. Here is another reason for the hesitation; riding the break petal or using the left foot on the break and breaking and accelerating at the same time. When the break petal is slightly pressed, it signals the computer and it cuts off gas momentarily. It was a bad habit of mine and once I started using my right foot for both breaking and gas, it was fine. With both those reasons solved, my Q7 is fine
#18
Dont ride the break petal or simultaneously break and accelerate. Any pressure on the break signals the computer to cut off gas. Also, have the mechanic check the “throttle body”. Replaced mine and hesitation went away
DenverAudiQ7
Q7 MK 1 Discussion
10-01-2015 07:38 PM
frybear
09-17-2015 01:31 PM
S4intheOC
09-08-2015 12:12 AM
bebopdeluxe
A6 (C7 Platform) Discussion
09-05-2015 04:11 PM
