295 width tires
I have seen a few on here with 295 tires but none on the 5 spoke sline wheels, my stock 275's seem very very close to the suspension piece in the front that sits just above the tire how much space is there between this and the 295 tires?
Thanks
Thanks
The 295 tires are normally used on the 21x10 wheels which have a +44 offset. This moves the tire out significantly from the 20x9 ET60 setup you're asking about. So the clearance between the two is really not comparable... it's apples and oranges. Plus I don't think you'll find a 295 tire that is rated for use on a 9" wide rim.
I didn't realize some of the 20 inch rims were different specs I though one of the persons with the 295 had said their rims were a 60 offset I will have to look through all the post again and check thanks.
Dr. Duct Tape
Q5/SQ5 MKI (8R) Discussion
08-03-2014 07:35 AM
brenner
Wheels & Tires Discussion
08-05-2004 07:41 AM
