Air suspension failing randomly and going down
Recently my 2014 Audi Q7 has started to have random problems with air suspension. I get 3 error messages on a dash: Headlight range failure, Air Suspension failure, TPMS failure and the car goes all the way down (I am guessing some sort of an air suspension limp mode). I can turn off the ignition, start the car back and all is good again: the car goes back to Auto position and I can drive.
From what I can tell the car seems to be loosing connection with few height sensors almost at the same time. Would that indicate the level control module is failing? I have a hard time believing the wiring is faulty (even with the poor quality of VW wiring harnesses) or the sensors themselves are faulty. Any other suggestions?
Two scans I grabbed after these events happened:
Sunday,11,April,2021,16:27:19:13569
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WA1VMBFE5ED010817 License Plate: CROVA
Mileage: 161400km-100289mi Repair Order: prereset
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 34 36 3C 42 46 47 4C
4F 52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1VMBFE5ED010817 Mileage: 161400km-100289miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 A HW: 4L0 907 401 E
Component: 3.0TDI EDC17 H23 0006
Revision: 54H23--- Serial number:
Coding: 2A2A4012257600050000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114L2910401A 001007
ROD: EV_ECM30TDI0114L2910401A.rod
VCID: 2241915135FAF09BF5-8076
1 Fault Found:
5604 - Park/Neutral Switch Input Circuit
P0850 00 [032] - Open or Short to Plus
Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ
Component: AL1000 AISIN 002 2454
Serial number:
Coding: 001378
Shop #: WSC 45500 002 1048576
ASAM Dataset: EV_TCMAL991031 002114
ROD: EV_TCMAL991031_002.rod
VCID: 7BFF8C35F2D0615396-802E
No fault code found.
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0627825
VCID: 346D6709570E6E2B17-8060
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702099834
Coding: 0000135
Shop #: WSC 03799 002 1048576
VCID: 254B8A4DECD407A390-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H04 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
4 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 148408 km
Time Indication: 0
Date: 2020.09.13
Time: 22:03:57
00191 - Passenger's Door Handle Touch Sensor (G416)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 148408 km
Time Indication: 0
Date: 2020.09.13
Time: 22:03:57
00193 - Rear Right Door Handle Touch Sensor (G418)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 148408 km
Time Indication: 0
Date: 2020.09.13
Time: 22:03:57
00192 - Rear Left Door Handle Touch Sensor (G417)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 148408 km
Time Indication: 0
Date: 2020.09.13
Time: 22:03:57
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000000402798
Coding: 0304A036
VCID: 254B8A4D2CD407A390-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0049130966
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0049116568
Coding: 070000
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0139123
VCID: 6ED9B56179A204FB21-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55931329000447
Coding: 29011E
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 346D67099F0E6E2B17-8060
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 A HW: 4L0 907 561
Component: ABSTANDSREGELUNGH07 0160
Revision: -------- Serial number: 00000000000000
Coding: 0031111
VCID: 2757804596D815B3A2-8072
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 72 AIRBAG AUDI8RH44 0230
Revision: 08H44000 Serial number: 0038QD0CFMGT
Coding: 0014130
VCID: 2B5F7C758A3031D346-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME6A354B60K
Subsystem 3 - Serial number: 6342QSME58353372C
Subsystem 4 - Serial number: 6352QSME78384766Q
Subsystem 5 - Serial number: 6362QSME58350672E
Subsystem 6 - Serial number: 63734SME7E363F52D
Subsystem 7 - Serial number: 63834SME7E3650767
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 B HW: 4F0 953 549 F
Component: J0527 0830
Revision: 00H09000 Serial number: 90026132480199
Coding: 0012252
VCID: 285583799BC61ACBAB-807C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 G HW: 4L0 920 985 G
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2T41J5CE
Coding: 8BDF64040D01D705020205
VCID: 387553398B668A4B3B-806C
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M13A26082C
Coding: 00C303
VCID: 3F873825AE48BD73FA-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 40308K57064121065702
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---011 Serial number: 00000030311358
Coding: 0000006
VCID: 68D5C3795B46DACB6B-803C
1 Fault Found:
00003 - Control Module
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 8
Reset counter: 255
Mileage: 151355 km
Time Indication: 0
Date: 2020.10.29
Time: 19:33:03
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 J HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7860
Revision: --H04001 Serial number: 15.1528-0143.2
Coding: 0015520
VCID: 31636E1DA81C5B037C-8064
5 Faults Found:
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 7
Reset counter: 35
Mileage: 158528 km
Time Indication: 0
Date: 2021.02.06
Time: 16:46:32
Freeze Frame:
Error Code: 68
01769 - Sensor for Vehicle Leveling; Front Right (G289)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 35
Mileage: 161156 km
Time Indication: 0
Date: 2021.04.06
Time: 15:30:10
Freeze Frame:
Error Code: 52
00775 - Level Control System Sensor; Rear Right (G77)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 35
Mileage: 161156 km
Time Indication: 0
Date: 2021.04.06
Time: 15:30:10
Freeze Frame:
Error Code: 54
00139 - Left Front Body Acceleration Sensor (G341)
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 3
Fault Frequency: 2
Reset counter: 33
Mileage: 161161 km
Time Indication: 0
Date: 2021.04.06
Time: 17:08:56
Freeze Frame:
Error Code: 192
00776 - Level Control System Sensor; Left Front (G78)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 35
Mileage: 161262 km
Time Indication: 0
Date: 2021.04.08
Time: 15:59:13
Freeze Frame:
Error Code: 24
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000049076563
Coding: 00581B00000011110000
VCID: 326161116D1A601B05-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH02 0050
Revision: 00H02000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E597561B92244FB61-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H02 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F17.10.1300H02000AMS15096ÿ
Subsystem 4 - Serial number: S15096ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000080130258
Coding: 011F57205E40440004
VCID: 489523F9FB86FACB4B-801C
2 Faults Found:
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Priority: 3
Fault Frequency: 52
Reset counter: 12
Time Indication: 0
02124 - Exterior Door Handle Switch
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 159394 km
Time Indication: 0
Date: 2021.02.15
Time: 22:25:00
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01940233390000
Coding: 3565853
VCID: 387553394B668A4B3B-806C
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000020182
Coding: 030000
VCID: 2953867D40CC23C3B4-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190084805
Coding: 0758733
VCID: 234F9455E2E0F993FE-8076
2 Faults Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 34
Mileage: 159737 km
Time Indication: 0
Date: 2021.03.08
Time: 17:22:05
Freeze Frame:
Hex Value: 0x000D
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 14.60 V
Temperature: 14.0°C
(no units): 120.0
01310 - Level Control System Control Module (J197)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 2
Reset counter: 36
Mileage: 161156 km
Time Indication: 0
Date: 2021.04.06
Time: 15:30:23
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 13.30 V
Temperature: 27.0°C
(no units): 0.0
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000162735
Coding: 0012001
VCID: 5EB9E5A18902947B91-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000080270954
VCID: 479720C5F698F5B342-8012
1 Fault Found:
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 29
Reset counter: 153
Mileage: 155419 km
Time Indication: 0
Date: 2020.12.01
Time: 18:28:10
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000032
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 161156 km
Time Indication: 0
Date: 2021.04.06
Time: 15:30:09
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 H HW: 4G0 035 082
Component: Radio U SIRIU H60 0138
Revision: AB001007 Serial number: 156K30D7928071
Coding: 020007010000000000
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4L2 035 746 H HW: 4L2 035 746 D
Component: H-BNT-NA H41 1040
Revision: -------- Serial number: 224K20D7534468
Coding: 180200060004FBEF710023456F632003140000000100000000
VCID: 336F6415920069130E-8066
Subsystem 1 - Part No: 8R0 060 884 CS
Component: NAR 2015 1201
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130KY0D2870724
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002148323
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5571
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000081520614
Coding: 010E57204040230004
VCID: 46892DC1F192ECBBB9-8012
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 6
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 159395 km
Time Indication: 0
Date: 2021.02.16
Time: 15:04:05
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000194782843
Coding: 0200000000000000
VCID: 31636E1D681C5B037C-8064
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0115413
Coding: 020C000001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6ED9B561B1A204FB21-803A
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H57 0500
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CDDBF694FBEF6EB0F-8038
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: 1
ó
Subsystem 3 - Serial number: RD31.10.13--H57001002F0275ÿ
Subsystem 4 - Serial number: 2F0275ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0080931608----
Coding: 0003595
VCID: 26498D4191D20CBB99-8072
Subsystem 1 - Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H14 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H14 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H14 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000081520400
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 244
Mileage: 159894 km
Time Indication: 0
Date: 2021.03.15
Time: 07:58:57
End-------------------------(Elapsed Time: 04:35)--------------------------
www.Ross-Tech.com
1 Fault Found:
Serial number:
Coding: 001378
Revision: 00H02001
Coding: 0627825
Coding: 0000135
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 148408 km
Time Indication: 0
Date: 2020.09.13
Time: 22:03:57
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 148408 km
Time Indication: 0
Date: 2020.09.13
Time: 22:03:57
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 148408 km
Time Indication: 0
Date: 2020.09.13
Time: 22:03:57
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 148408 km
Time Indication: 0
Date: 2020.09.13
Time: 22:03:57
Coding: 0304A036
Coding: 070000
Coding: 070000
Coding: 0139123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Coding: 29011E
Coding: 0031111
Coding: 0014130
Coding: 0012252
Coding: 00C303
Coding: 0000006
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 255
Mileage: 151355 km
Time Indication: 0
Date: 2020.10.29
Time: 19:33:03
Coding: 0015520
5 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 35
Mileage: 158528 km
Time Indication: 0
Date: 2021.02.06
Time: 16:46:32
Freeze Frame:
Error Code: 68
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 35
Mileage: 161156 km
Time Indication: 0
Date: 2021.04.06
Time: 15:30:10
Freeze Frame:
Error Code: 52
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 35
Mileage: 161156 km
Time Indication: 0
Date: 2021.04.06
Time: 15:30:10
Freeze Frame:
Error Code: 54
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 33
Mileage: 161161 km
Time Indication: 0
Date: 2021.04.06
Time: 17:08:56
Freeze Frame:
Error Code: 192
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 35
Mileage: 161262 km
Time Indication: 0
Date: 2021.04.08
Time: 15:59:13
Freeze Frame:
Error Code: 24
Coding: 0010001
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 52
Reset counter: 12
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 159394 km
Time Indication: 0
Date: 2021.02.15
Time: 22:25:00
Coding: 3565853
Coding: 030000
Coding: 0758733
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 34
Mileage: 159737 km
Time Indication: 0
Date: 2021.03.08
Time: 17:22:05
Freeze Frame:
Hex Value: 0x000D
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 14.60 V
Temperature: 14.0°C
(no units): 120.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 36
Mileage: 161156 km
Time Indication: 0
Date: 2021.04.06
Time: 15:30:23
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 13.30 V
Temperature: 27.0°C
(no units): 0.0
Coding: 0012001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 29
Reset counter: 153
Mileage: 155419 km
Time Indication: 0
Date: 2020.12.01
Time: 18:28:10
Coding: 0000032
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 161156 km
Time Indication: 0
Date: 2021.04.06
Time: 15:30:09
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 6
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 159395 km
Time Indication: 0
Date: 2021.02.16
Time: 15:04:05
ó
Coding: 0003595
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 244
Mileage: 159894 km
Time Indication: 0
Date: 2021.03.15
Time: 07:58:57
Saturday,17,April,2021,11:43:53:13569
www.Ross-Tech.com
Mileage: 161640km-100438mi Repair Order: prereset
VIN: WA1VMBFE5ED010817 Mileage: 161640km-100438miles
28-HVAC, Rear -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
Serial number:
Coding: 001378
Revision: 00H02001
Coding: 0627825
Coding: 0000135
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:41:16
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:41:16
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:41:16
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:41:16
Coding: 0304A036
Coding: 070000
Coding: 0139123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Coding: 29011E
Coding: 0031111
Coding: 0014130
Coding: 0012252
Coding: 00C303
Coding: 0000006
Coding: 0015520
5 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 38
Mileage: 161403 km
Time Indication: 0
Date: 2021.04.11
Time: 20:25:42
Freeze Frame:
Error Code: 68
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 161623 km
Time Indication: 0
Date: 2021.04.15
Time: 19:18:20
Freeze Frame:
Error Code: 52
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 161624 km
Time Indication: 0
Date: 2021.04.15
Time: 19:21:45
Freeze Frame:
Error Code: 54
00774 - Level Control System Sensor; Rear Left (G76)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 161624 km
Time Indication: 0
Date: 2021.04.15
Time: 19:21:45
Freeze Frame:
Error Code: 53
01575 - Control Switched Off
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 161641 km
Time Indication: 0
Date: 2021.04.17
Time: 11:33:58
Freeze Frame:
Error Code: 69
Coding: 0010001
Coding: 3565853
Coding: 030000
Coding: 0758733
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 41
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:31:15
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 14.40 V
Temperature: 24.0°C
(no units): 0.0
Coding: 0012001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:26:23
Coding: 0000032
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 1
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:31:02
ó
Coding: 0003595
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:26:23
End-------------------------(Elapsed Time: 04:29)--------------------------
www.Ross-Tech.com
Serial number:
Coding: 001378
Revision: 00H02001
Coding: 0627825
Coding: 0000135
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:41:16
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:41:16
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:41:16
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:41:16
Coding: 0304A036
Coding: 070000
Coding: 0139123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Coding: 29011E
Coding: 0031111
Coding: 0014130
Coding: 0012252
Coding: 00C303
Coding: 0000006
Coding: 0015520
5 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 38
Mileage: 161403 km
Time Indication: 0
Date: 2021.04.11
Time: 20:25:42
Freeze Frame:
Error Code: 68
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 161623 km
Time Indication: 0
Date: 2021.04.15
Time: 19:18:20
Freeze Frame:
Error Code: 52
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 161624 km
Time Indication: 0
Date: 2021.04.15
Time: 19:21:45
Freeze Frame:
Error Code: 54
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 161624 km
Time Indication: 0
Date: 2021.04.15
Time: 19:21:45
Freeze Frame:
Error Code: 53
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 161641 km
Time Indication: 0
Date: 2021.04.17
Time: 11:33:58
Freeze Frame:
Error Code: 69
Coding: 0010001
Coding: 3565853
Coding: 030000
Coding: 0758733
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 41
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:31:15
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 14.40 V
Temperature: 24.0°C
(no units): 0.0
Coding: 0012001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:26:23
Coding: 0000032
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 1
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:31:02
ó
Coding: 0003595
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 161401 km
Time Indication: 0
Date: 2021.04.11
Time: 16:26:23
I would clear all faults and rescan. The symptoms seemed to point to Battery low or going out. Check the battery. The Power management system may disable some functions to save the battery when needed.
If the suspension is erratic, do a simple test to find out which strut is leaking.
-put suspension to lift mode.
-put suspension in jack mode.
-leave it for a few hours to see which side(s) is lowered, it would be thats strut is leaking. Verify with soap and water to see bubbles.
Check my post with the A8 suspension in my signature to learn more.
Cheers,
Louis
Cheers,
Louis
jtl60047 (04-20-2021)
Basenco
14
02-21-2018 02:57 AM
ajg617
32
01-20-2015 04:55 PM
