A/C drain clogged
Water started coming down into both the passenger and driver foot rest (tho more on the passenger side). So much that the passenger side floor mat is soaked. Since my car is garaged in doors, and it has rained the last 2 days, I knew it wasn't the sunroof. I'm assuming the air conditioning drain is clogged. Is this a DIY or do I wait until next week to take to the dealer. I'll probably take to the dealer since I have the extended warranty but hoping to fix it now instead of waiting since I need to drive the family this weekend.
DIY if you want.
Previous thread with pics
![Name: condensatedrainRHDJPG2.jpg
Size: 82.0 KB](https://www.audiworld.com/forums/attachments/q7-mk-1-discussion-112/79482d1501280337-c-drain-clogged-condensatedrainrhdjpg2.jpg)
I think if you search you might find another thread with details of some anti bacterial spray.
Not covered under warranty, sad sad sad...
1st vehicle I have owned where A/C & Sunroof hoses need to be cleaned at all, let alone not covered under warranty... "clogging & cleaning is not part of warranty" What an Absolute Joke for a vehicle with this price tag. Utterly Ridiculous... Make a poor design, then try to make money on it for a fix they should be doing as a service bulletin/recall etc.
you may have some luck cleaning out the discharge from under the car and using a disinfectant spray the other poster was talking about...most likely what you have is green slime in your system. try not to run your a/c on recirculate/max all the time and turn off the a/c with the blower on, fresh air so the evaporator coil doesnt stay wet all the time.
AudiWorld Expert
It should be a warranty issue - as it is not something that you caused. I would protest to AOA
I've had that issue before with other brands (BMW) and they covered it.
Funny- over on the BMW forums I frequent, I hear the same kinds of complaints I read here(ie BMW being stingy with warranty stuff). I think your impression may change if you had a new one(assuming you don't - that is...). My experience with BMW warranty was pretty good although I had few issues. My Audi experience has been good as well.
they werent perfect, but it was nice to know that a ~$1000 brake job was covered
