camshaft adjustment
My Q7 Keep gives me thease error codes below:
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 36
Mileage: 226553 km
Time Indication: 0
Date: 2012.12.29
Time: 17:16:21
Freeze Frame:
RPM: 1373 /min
Load: 36.1 %
Speed: 47.0 km/h
Temperature: 85.0캜
Temperature: 6.0캜
Absolute Pres.: 1010.0 mbar
Voltage: 14.351 V
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28): Incorrect Correlation
P0016 - 008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 227433 km
Time Indication: 0
Date: 2013.01.06
Time: 13:52:20
Freeze Frame:
RPM: 2070 /min
Load: 72.9 %
Speed: 89.0 km/h
Temperature: 88.0캜
Temperature: 6.0캜
Voltage: 14.224 V, I ch
And later I read some threads about camshaft adjustment....
I got this from my car....below:
Address 01: Engine (03H 906 032 L)
12:03:25 Group 090: Continuous Camshaft Adjustment Exhaust Bank 1
680 /min Engine Speed (G28)
5.9 % Exhaust Camshaft Duty Cycle
-25.0캩W Adjustment (specified)
-25.5캩W Adjustment (actual)
12:03:25 Group 091: Continuous Camshaft Adjustment Intake Bank 1
640 /min Engine Speed (G28)
32.9 % Intake Camshaft Duty Cycle
18.0캩W Adjustment (specified)
17.5캩W Adjustment (actual)
12:03:25 Group 093: Camshaft Adaption Values Intake
16.5 % Engine Load
-6.0캩W Adaptation Angle Bank 1
-1.0캩W Adaptation Angle Bank
I do not know about specs...
What does this mean? and What can I do? Is my car ok? It runs funny, though....
If anybody has an idea to crack this code...means explain...please.
Thank you for your help.
Freeze Frame:
Fault Priority: 0
Fault Frequency: 36
Mileage: 226553 km
Time Indication: 0
Date: 2012.12.29
Time: 17:16:21
Freeze Frame:
RPM: 1373 /min
Load: 36.1 %
Speed: 47.0 km/h
Temperature: 85.0캜
Temperature: 6.0캜
Voltage: 14.351 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 227433 km
Time Indication: 0
Date: 2013.01.06
Time: 13:52:20
Freeze Frame:
RPM: 2070 /min
Load: 72.9 %
Speed: 89.0 km/h
Temperature: 88.0캜
Temperature: 6.0캜
16.5 % Engine Load
The complication of the problem went suddenly easy thing.
I took the car to a dealer to check other things such as leakage on sealings and gskets. I have 150,000 miles on the car already. So, I thought that is a good time to check them.
And they suggested me to change filter and spark plug. Because I never change them since I bought the car which is 2007. I know... I travel a lot, over the mountains, cross the sandy field, dusty country roads and some time cross the little creeks. No one, include dealer, ever mention about it. So, anyway I changed filter and I also cleaned the spark plugs, there was some deposits. And gusee what, everythings are fine. My car runs so smooth and feel so light, no glumbling, gagling or shaking. No problems with anything for now.
If the car give me the same code again then, I will go with your advice. Thanks.
Thank you for your reply.
Thank you for the info. I will check the issue with dealer so, they can do it under warrenty.
My warrenty expired an year ago. And now it has 150,000miles on it. It is very questionalble but worth a shot. And actually, I wanted to know what is the ptoblem, so I can fix it, if it is fall on to my capability.
Hope that no problem as long as it can be.
I appreciate you, again.
OrlandoDave
A4 (B7 Platform) Discussion
12-26-2023 01:19 AM
geordie
02-26-2008 05:17 AM
