Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Caution: Keep away from the "Bootloader"?
Old 04-10-2014, 09:05 PM
Andyly's Avatar
Default Caution: Keep away from the "Bootloader"?
I have been reading what VCDS/Vag-com can do to MMI and adding afew features to the car. But I keep seeing this "warning Caution keep away from bootloader?"
Can someone care to explain what that exactly mean and when do I see this?
Thanks
Old 04-13-2014, 11:38 PM
DieselDave's Avatar
The bootloader is accessed via a menu system that needs to be activated for you to see it. The hidden menu contains some settings that can be tweaked to activate / modify features within the MMI.
The bootloader options basically tells the unit to reset itself and requires the correct firmware CD to reload the MMI. Without it the system is unusable.
If you have a 2G MMI system, the firmware can be obtained from sources around the web. I have not seen the firmware for a 3G system available, but that doesn't mean it's not.
Bottom line, keep away from the bootloader
Old 04-14-2014, 07:09 PM
Andyly's Avatar
Thank you for the reply.
My first thought was somewhere during the vcds step and its bootloader reboot or show on the screen that might caused the problem.
After I did afew search, only happen if u go inside the "green menu" and changing/playing around with bootloader section
Thanks for that
1sato
Q5/SQ5 MKII Discussion
02-03-2019 02:55 PM
rbreeze
A4 (B9 Platform) Discussion
02-02-2017 06:29 PM
N4me
Q7 MK 1 Discussion
07-24-2009 12:43 PM
rkraus
01-03-2009 10:22 AM
Quick Reply: Caution: Keep away from the "Bootloader"?
