CEL help
Our 2007 Q7 threw a couple of codes last night and I'm not sure exaclty what it means.
Any help would be greatly appreciated.
012408 - Throttle Control: Airflow at Idle too Low
P3078 - 002 - Lower Limit Exceeded
001110 - EVAP System: Very Small Leak Detected
P0456 - 001 - Upper Limit Exceeded - MIL ON
Thanks
Thanks
Thanks
Thanks
Believe on the 07 Q emissions are covered 8 years or 80,000 miles. I had surpassed the 80,000 miles. Did have extended warranty which covered some of the labor and the sensor.
How much did U pay for the LED lights ? how was the installation, any errors from the dash ? any pictures
Did the install myself except had the dealership do a final OEM type hard wire connection to the correct ECU and power. You will have to swap the turn lights location with the original DRLs. You or the dealership will also need to go into vagcom and completely turn off the U.S. coding for DRLS as the LED have a separate control unit supplied. (Or you will get errors)
Also had to translate the instructions supplied as they are in German.
http://www.media-cartec.de/product_i...rleuchten.html
Didn't mean to hijack the thread...........
a4_1.8t_01
11-07-2008 06:17 PM
Barry in Utah
VAG-COM Discussion
09-26-2008 12:30 AM
