Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
CEL P0089 Fuel Pressure Regulator
Old 12-02-2015, 06:13 AM
Netopr's Avatar
Default CEL P0089 Fuel Pressure Regulator
I have had this code in my 2008 Audi Q7 3.6L for a while and after some research in the past, this is a tough one to fix on Audi vehicles.. This code can be triggered by malfunction of many components like the fuel pump, High pressure fuel sensor, low pressure fuel sensor, dirty fuel filter or even the cam sensor.
I have yet found out an incident specific to the Q7 so I am asking here if any of you have experience this code and what did you replace to fix it?
thanks!
Old 12-02-2015, 02:49 PM
smith2010Q7's Avatar
replace fuel filter in your fuel tank
i think you have two of them one on each side.
Old 12-02-2015, 04:32 PM
geng77's Avatar
lmao.. just had the same problem on my 07' 3.6L.. replaced the fuel filter in the tank and that should fix it. you might want to replace the fuel pump while you're at it too if you can spend a little extra. it will probably save you in the long run.
don't spend money on the sensors and crap under the hood.. doesn't do anything.
Old 12-03-2015, 07:10 AM
Netopr's Avatar
I did replace one fuel filter around two weeks ago. I replaced the one under the back seats driver side. Is there another filter on the back seats passenger side?
I bought the whole filter housing that included the filter in it, do you know if we can get the filter itself?
Thanks
Old 12-03-2015, 06:46 PM
My bad look it up inside the manual. One side is the filter and the other side is the pump.
you can do both with a filter (it self) or (filter and housing).
My opinion since your have a 08 and this might be the 1st time i recommend for the whole unit, cause plastic case can be crack or will in the future cause of it been to old.
V10R8
A4 allroad (B8 Platform) Discussion
05-26-2019 11:12 AM
prijedor
A4 (B7 Platform) Discussion
04-19-2018 06:24 PM
kingfishgrapejam
03-15-2014 05:18 AM
keithsan
9
03-28-2013 09:02 AM
in2audi
07-28-2004 07:34 AM
Quick Reply: CEL P0089 Fuel Pressure Regulator
