Changing fog lights on 2010 Q7 for brighter bulbs...
Hello,
I am looking to brighten up my Q7 OEM Fog Lights. Can someone please recommend what I should use?
I was thinking just a simple H7 bulb replacement; however, if I did that, I am not sure what color would be best? Perhaps I could match the LED parking lights?
Or should I go with a LED or Xenon bulbs?
What is the best???
Thank You!
What is the best???
Thank You!
Yea, I'm looking too!
FYI though, I purchased some replacement LED H7 bulbs to see if they'd fit and they don't! The current H7 fog bulbs have a metal base that has the spin connector on them so that when you put the bulb in, it locks into place. I'm trying to find an HID xenon bulb kit that has this locking mechanism in it as well so I can just swap them. If I find anything, I'll let you know.
Bimmeup
Bimmeup
I was just looking at some pictures of different bulbs, and it seems to me that the fog lights on the 2010's may not be H7 bulbs? I don't know if there is any way to find this out because if I search for replacement bulbs, everything shows up as H7. I just have to wonder if they changed them for 2010 and it's just now showing up yet because these Q7's are so new?
Bimmeup
Bimmeup
Thank you...
I have heard that there have been situations where the housing for the bulb has melted because of the heat from an over powered bulb.
I ended up paying for a Putco 55W Yellow bulb to replace what is in there.
Do you know how to pull the bulbs out?
Thanks!
Thanks!
First of all, whichever side you work on, you'll have to make sure you turn the wheel towards the outside of the wheel well. Now, you'll have to take out some of the hex screws that lock the wheel well lining. Also, there's that small plastic mud flap which has a set screw at the bottom of it and up the side a bit too. Once you get those out, you'll be able to lye on your back under the front fender, pull the lining back and reach inside of the fog housing. The fog light is turned to unlock and lock it into place so you should be able to just unlock it, then unplug the oem fog, plug the new one in, lock it in place and then replace all of the hex screws.
One thing, the liner and the front mud flap all interlock within eachother so once you've unscrewed those, don't pull out the liner completely. Make a note to yourself on how the flap and liner all go back together so that the holes line up correctly. Also, you shouldn't have to unscrew the hex screws along the top of the liner in the wheel well, that way, it's not completely hanging off or creating an issue.
Bimmeup
removal/installation is fairly simple. the average time replacement of your bulbs can only took 20 minutes or less. i already tried it and its so much easy..
