Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Detailed Dension Gateway 500 Installation instructions w/ lots of pictures...
Old 03-24-2008, 01:47 PM
  #11
nebalt's Avatar
Default Excellent question.....For NAV yes but not for SAT radio...pls read
I also retrofitted a NAV and for this, I indeed needed to drop the roof panel to get to the FAKRA antenna cable for the NAV. An extension cable was snaked down to the wheel well for the NAV unit. In my case, the SAT antenna was already snaked all the way down to the cubby hole where the SAT radio goes but not for the NAV. I cannot understand why Audi did it this way.
Old 03-25-2008, 12:44 PM
  #12
vr430's Avatar
Thanks! Did anyone try BT accessory for A2DP capability?
Old 03-26-2008, 09:59 PM
  #13
drx604's Avatar
does this OEM XM install work on 08s as well? or just certain 07s?
Old 03-27-2008, 06:59 PM
  #14
nebalt's Avatar
Both '07 and '08
Old 03-27-2008, 09:36 PM
  #15
drx604's Avatar
do u just need the module.. or is there some wires needed for this install?
Old 10-05-2008, 11:53 AM
  #16
daredevil1's Avatar
Default Re: Detailed Dension Gateway 500 Installation instructions w/ lots of pictures...
"The adapters will be released allowing the fiber cables for connection. "
Where do they connect?
Old 11-17-2008, 06:38 PM
  #17
devious53's Avatar
I'm trying to install an icelink 500. My cd changer is stuck and will not move, what am i doing wrong. I have the keys. Anyone know how to remove the vents instead?
Old 12-11-2008, 03:34 PM
  #18
New Member
barzotto's Avatar
Default voltmeter problem
hi
I'd like to know how did you check with a voltmeter to make shure that a slot is 12V ?
Did you checked with the fuse in place or not ?
Sorry but I'm a little confused about this passage
thanks in advance
Old 03-20-2009, 05:47 PM
  #19
nebalt's Avatar
That part is really tricky. You have to use good bit of force to try and pry the CD changer free from under the vents.
Old 03-20-2009, 05:52 PM
  #20
nebalt's Avatar
If I remember correctly, all you need to do was press the constant (red) lead to the empty (fuse) slot.
Quick Reply: Detailed Dension Gateway 500 Installation instructions w/ lots of pictures...
