Driver's Seat Problem
I'm having a problem in my 2007 Q7 4.2 with my driver's seat. I have the seat memory option. Currently the driver's seat will on tilt forward so far, however not all the way. I initially thought the switch and/or the motor was too blame. Seat will tilt all the way back and will move forward to a point but not all the way. This rules out both. Is there any way to reset the seat? Thanks.
This is the crazy problem that we have. A lot of times to reset something we disconnect the battery by reseting the default memory. Since it is under the seat to much work to do the job.
Has this been proven to work for this specific problem or is it just something to try?
That might work for american cars, however I don't want to have to get into a steering angle calibration debacle with this thing because it lost all of it's settings.
So I finally had a chance to hook up my VAGCOM after the holidays. Received the below fault.
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082954
Shop #: WSC 31414 790 00001
VCID: 61C9A799B8707F29005-8034
1 Fault Found:
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 2
Reset counter: 232
Mileage: 131840 km
Time Indication: 0
Date: 2014.12.09
Time: 21:18:37
Not present on the VCDS Wiki and I can't find the G230 module in any of my documentation. Any ideas?
Coding: 0082954
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 232
Mileage: 131840 km
Time Indication: 0
Date: 2014.12.09
Time: 21:18:37
I could not find G230, but I think I have everything to replace your seat angle adjustment comp.
You will have to removed the driver seat which it is under the seat next to the seat memory comp.
attachments below should help you plus a overview of every seat adjustment comp.
Hope this helps![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Drive seat angle adjustment test.pdf
seat angle overview.pdf
seat component overview.pdf
Hope this helps
Attachment 43808
Attachment 43809
Attachment 43810
Hope this helps
Attachment 43808
Attachment 43809
Attachment 43810
So do you think the angle adjustment is bad?
I guess the final troubleshooting will be to remove the plug and put power to the motor and see if it moves the full tilt angle.
