DRL 2008 Q7
Hey guys,
Just bought my first Audi. 2008 Q7 3.6 Premium. I live in Canada and have to get a motor vehicle inspection completed before I can get it licensed. Before I can do that I need to have Daytime Running lights which are not included with my Q7 equipped with halogen headlamps. I tried the MMI but the DRL function is greyed out and not accessible.
Does anyone know if the DRL's can be turned on using a VAG or even if an Audi dealer can do it without having to buy the conversion kit?
Only Audi dealer near me is 250 miles away and when I talked to the tech I did not get a good feeling he knew what I was talking about, and I do not want to waste a day driving there if they cannot do it anyway.
So far LOVE the Q7....Hooked on Audi after two weeks.
Hope this helps. Dealer should also be able help as stated above if needed.
Using VAG COM
Central elect 09
Coding the control unit
The code is composed as follows:
First position from left:
0: Blank
Second position from left: -Steering column adjustment-
0: With manual steering column/electronic steering column without memory
(PR no. 2C5+2C7+3L3/3L5/3PB)
1: With electronic steering column with memory (PR no. 2C7+3L4/3PN)
Third position from left: -Footwell light-
0: Footwell light fitted as bulb (PR no. QQ0)
1: Footwell light fitted as LED (PR no. QQ1)
Fourth position from left: -Headlights-
0: Halogen headlights without headlight washer system (PR no. 8Q0/8Q1+8X0)
1: Halogen headlights with headlight washer system (PR no. 8Q0/8Q1+8X1)
2: Bi-xenon headlights with headlight washer system (PR no. 8Q3+8X1)
3: Bi-xenon headlights with AFS (PR no. 8Q5+8X1)
4: Bi-xenon headlights without headlight washer system (PR no. 8Q3/8Q5+8X0)
5: LED daytime running lights with headlight washer system
6: LED daytime running lights without headlight washer system
Fifth position from left: -Assistance driving lights-
0: Without automatic driving lights (Auto) (PR no. 8K0/8K1/9C6)
1: With automatic driving lights (Auto) with rain and light sensor -G397
(PR no. 8K3/8K7/8K9/9C7)
2: With main beam assistant
Sixth and seventh position from left: -Country variant/daytime running lights-
01: Countries which prohibit daytime running lights
(PR no. 8BB/8BF/8BJ/8EC/8ED/8EH/8EJ+B19/B24/B28/B29/B36/B39/B40/B41/B46/B48/B49/B52/B54/B60/B62/B68/B83/B84/B85/B86/B87/B88/B89/B90/B91)
01: Countries with separate daytime running lights solution, without daytime running lights
(PR no. 8BB/8BF/8BJ+B00/B01/B02/B03/B09/B10/B13/B14/B15/B16/B18/B21/B26/B27/B30/B31/B32/B42/B43/B51/B59/B61/B64)
21: Countries with separate daytime running lights solution, selectable with daytime running lights
(PR no. 8EC/8ED/8EH/8EJ+B00/B01/B02/B03/B09/B10/B13/B14/B15/B16/B18/B21/B26/B27/B30/B31/B32/B42/B43/B51/B59/B64/B79/B61)
02: Countries with enhanced daytime running lights solution, without daytime running lights
(PR no. 8BB/8BF/8BJ+B08/B17/B20/B22/B25/B33/B37/B50/B53/B56/B65/B67/B74/B75/B76)
12: Nordic countries/Baltic states/Croatia/Slovenia/Austria, not selectable with daytime running lights
(PR no. 8BB/8BF/8BJ+B04/B05/B06/B07/B11/B12/B44/B45/B70/B71/B72)
22: Nordic countries/Baltic states/Croatia/Slovenia/Austria, selectable with daytime running lights
(PR no. 8EC/8ED/8EH/8EJ+B04/B05/B06/B07/B11/B12/B44/B45/B70/B71/B72)
22Countries with enhanced daytime running lights solution, selectable with daytime running lights
(PR no. 8EC/8ED/8EH/8EJ+B08/B17/B20/B22/B25/B33/B37/B50/B53/B56/B65/B67/B74/B75/B76)
03: USA, without daytime running lights
(PR no. 8BB/8BF/8BJ+B34)
23: USA, selectable with daytime running lights
(PR no. 8EC/8ED/8EH/8EJ+B34)
14: Canada, not selectable with daytime running lights
(PR no. 8BB/8BF/8BJ/8EC/8ED/8EH/8EJ+B35)
Coding example: 0000001 (reading from left to right)
0: Blank
Using VAG COM
Central elect 09
0: Blank
0: Blank
My A6 had halogens with no DRLs. I enabled them with VCDS, although it's not really DRLs, but the headlights came on when the car was started.
Setting last two digits of Central Electrics module 09 to 24 should enable DRL selection in the MMI (the 2) and set the country code to Canada (the 4).
When I set the last digit to 4, it switched the foglights on instead of the headlights. This was a UK spec car though, so YMMV as to which lights are switched on.
Hope that helps
Hope that helps
Yes. Setting coding as per my post above yours will enable DRL selection in MMI and switch on your headlights to use as DRLs.
A6 and Q7 were using the same modules at that time so you should get the same results.
As long as you make a note of the coding before you change it, if it doesn't work for you it's easy enough to set it back to what it was.
Yes.. Its done with me.
Now i can ON/OFF the DRL from the MMI 2G
However,
The DRL should be dimming low at night when i turn the headlight on.
In my case, the DRL bright 100% all time!
Any Idea how to do it?
This YouTube shows what I mean:
Thank you
However,
Thank you
dvs_dave
23
11-09-2015 12:46 AM
robarsan
04-24-2004 07:24 AM
