DRL LED Experiment
#12
To followup on my DRL experiment,I found some CANBUS chipped (eliminates bulb out warning) LED bulbs to replace the OEM DRL incandescent bulbs, and installed them to match the DRL lights I installed previously. I'm pretty happy with the look and the lights are very bright during the day, and look awesome at dusk/nighttime. I'm planning to replace the OEM fog lights with these bulbs but might go with HIDs instead.
What do you guys think?
#13
It matches the DRL you previously installed. Where did you buy the bulbs from?
#15
I got the LED lights from:
http://store.ijdmtoy.com/ProductDeta...Audi_DRL_SKU77
It only comes in one length (12") Thats why I didn't mount it under the turn signals. I would of had to cut some of the plastic, and I though it would look to random under the turn signals because they're short. I admit they are pretty bright they have 9 1 watt LED's so they are bright from all angles. I wired them to the DRL. I'll ride with them for a little while and decide whether to keep them there or not.
#17
Sorry For the delay on the post, I just got back in town. The LED replacement bulbs for the OEM DRL are BA15s (1156 single circuit bulbs) Do not buy the 1157 dual circuit bulbs since the leads are offset and will not work.
You can buy them from :
http://autolumination.com/1156_1157.htm
I've bought numerous LED bulbs from these guys for my motorcycles and my cars, they are a good company with great customer service.
The ones I am using are the 23 High Powered Wide Angle SMT LEDS. They come in White, red or Amber, I have the White ones. When you click on the link, scroll down almost to the end. They cost $14.99, make sure you buy the BA15s that matches this description:
These Bulbs have Advanced Surface Mount Technology LEDS + Advanced Patented Circuitry
20 high powered SMT side facing LEDS - 3 high powered SMT forward facing LEDS
Only 20mm diameter x 52mm overall - fits all stock housings
High Powered 3 Chip SMT Leds - Outfitted with Canbus Bulb-Out Warning Cancellation Chip
Designed to eliminate most electronic bulb-out warnings in BMW, Mercedes, AUDI, VW, Volvo, and most others.
Hope this helps, I highly recommend these bulbs, and no bulb out warnings!
#18
Awesome. Thanks for the info; just ordered a pair.
I've noticed that the interior lighting is rather dim, especially in the 2nd row and with the brightness setting all the way up. Got any suggestions for what bulbs to use there?
#19
GomerPyle
I'm waiting to get the Q7 Service manual so i can take apart the Dome/Map light housing without breaking it. : )
The OSRAM -Sylvania LAMP replacement guide refers to the Map/Dome light as a 6411 bulb that would translate to a 6418, 38mm Festoon Dome LED bulb, similar to the LED bulbs I have in my tail lights. Don't quote me since I have not taken apart the Dome/map housing to verify. I'm planning to upgrade the dome light to White LED's and the map lights to Red LED bulbs. Let me know if you figure out how to take apart the dome/map light housing. I'll post pics as soon as I can get around to doing it myself.
#20
Tail lights
Thanks
