■Emergency!!■ about Headlight Range Control Defective
Hi all
i really needs help about "Headlight Range Control Defective" warning light and actually headlight range control doesn't work
i have vagcom so i've ran and tried everything but still not working....
01535 - Control Circuit for Right Headlight Range Adjusting Motor
so. let me tell you what happened before that showed up.
i have ordered OEM headlight ballast for my audi q7 3.0TDI and i've just replaced it without any problem.
i've plugged power into the right headlight and i forgot to plug the left headlight power and i turned on car.
and that error showed up so i've shut off the car and plugged right side headlight power.
when i turned car on, the headlight always been up and down but this time it didn't work with that fault code up
i have reset everything from vagcom and still not working.
I am thinking put the original ballast back and try it again
plzzz help me out !! it is so emergency
I have to go back to the army base in a day so i don't have lots of time to figure the problem out
thanks all for help
![](https://cimg7.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1504/20181218_031045_88becff562d04447b1ed9346590aece312803afe.jpg)
thanks all for help
You cleared the faults and its still, popping up a fault?
Audi Q7 (4L) - Ross-Tech Wiki
Audi A6 (4F) Headlight Aim Control (Adaptive Light) - Ross-Tech Wiki
So i just removed new ballast and then i replaces original ballast and headlight range control still not working it aim down from first
You need to click the link I posted, and follow the headlight adaptation (Aiming) procedure.
Basic Setting
Headlight Adjustment
[Select]
[55 - Xenon Range]
[Basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The adjustment should now be learned.
[Done, Go Back]
Don't forget to check/clear fault codes afterwards.
[Close Controller, Go Back - 06]
[Select]
[55 - Xenon Range]
Group 001
[Go!]
[ON/OFF/Next]
- The meas. block field now shows "Wait" and should switch to "Adjust Headlights" then (this may take up to 10 seconds).
- Adjust the headlights using their manual adjusting screws as referenced against a suitable aiming target.
[Done, Go Back]
Basic Setting
[Select]
[55 - Xenon Range]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
[Select]
[55 - Xenon Range]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Hmmm well mine is 08 Q7 so may not have many options than other years and vcds 15.7.1 is what i have it here
![](https://cimg5.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1504/20181218_042100_57b38f8533f955f5966044c824900b1725161a00.jpg)
Did that get your headlight to re-align?
Try this one:
https://www.audizine.com/forum/showt...non-Headlights
Its going to be that sort of procedure that will clear your error. That comes from this thread:
https://www.audiworld.com/forums/q7-...g-com-2906845/
DRV HRD
11-22-2007 08:56 AM
mroberts
07-25-2003 08:59 PM
