Exhaust Tips & Mud Flaps
#21
The tips do get dirty
I clean mine with simple old "Bon Ami"
I have also used brake cleaner in the past which works extremely well as most deposits are carbon based, just use in a ventilated area.
Worst case scenario, if they get so bad and discolored you can also try painting them with a product from Rustoleum. Just remove the whole tip section of exhasut and spray/paint a section you won't see and let it dry so you can see what it looks like before deciding if you like it for the visible section. A nice dark metallic "gunmetal" finish would be a nice alternative to chrome and a finish you see occassional on some OEM tips
Just cleaned my tips on my '09 335 which had a LOT of carbon buildup and nothing appeared to work, even the Bon Ami with a Blue scotch pad (non-scratch). Had to step up to using some fine wire wool and Bon Ami and it all came off nicely.
#22
Pics would be nice. Updates Welcome. Everytime I see the new 2010 TDI I get a twinge of disgust that Audi couldnt put some polished tips on the 3.6. As stated many times, even Kia and Heyundie put polished tips on their econoboxes. Sad Sad Sad
#24
In these pictures you can see the mufflers installed on my Q7. Ordered them from Hong Kong on e-bay. Very easy to install, just slipped over the originaly ones. May be different opinions of the result, looks a bit bigger than the original ones. Looks a bit cheep maybe..?
#27
The cut is not straight, but with a different/smaller angle than the original ones under. This is visible as long as the inside is not covered with black carbon particles. Probably just a matter of time.
Except from this, the mufflers look very good, and the quality is impressive considering the price. I believe I paid around $40 including shipment from Hong Kong to Europe.
I replaced the original 3 screws on each muffler with stainless ones. Probably not necessary, but I had them available.
#29
