Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
install led headlight
Old 09-07-2012, 07:04 AM
  #31
coupegt87's Avatar
Hi Leon,
What if I have the Kuftec cables and it has 4 wires with hooks ?
1) question, the 4 wires coming out of the cables have number on them Pin 1, Pin 16, Pin6, Pin 6, do I plug this into the J519 module or can I wire this to another source ? Thank you for any inputs...
B. regards,
Mark
Old 09-07-2012, 02:23 PM
  #32
xlr8it's Avatar
Originally Posted by coupegt87
Hi Leon,
B. regards,
Mark
2 wires (C 6 and C 16) have to be wired into the J519 you do not have to connect the other two
then code the 09 module to xenon headlights W/O washers
Old 09-10-2012, 06:11 AM
  #33
coupegt87's Avatar
Hi Leon,
Thank you Very Much for your expertise, one more thing, if I have a 2012 model is the recode the same ( 0015121 ) ?
Old 09-10-2012, 11:06 AM
  #34
Kc Taylor's Avatar
Originally Posted by xlr8it
yes correct
what code did you use after the install ?
Old 10-05-2012, 06:45 PM
  #35
Kc Taylor's Avatar
hey i did everything you told me to do but now the led come on as a daytime running light and when the sun go down the hid kick in and led go off. is it a way that i can have both on at the same time ?
Old 10-06-2012, 08:10 PM
  #36
xlr8it's Avatar
they should not turn off with the headlights on. If i had to guess I would say you have used the wrong earth wire it must be going positive when the HIDs are on, find a permanent earth wire for the LEDs.
Old 10-07-2012, 04:43 AM
  #37
Kc Taylor's Avatar
ok. where i find the earth wire at and once i find it what i do next ?
Old 10-07-2012, 04:47 AM
  #38
Kc Taylor's Avatar
would the earth wire be the ground wire ?
Old 10-07-2012, 01:27 PM
  #39
xlr8it's Avatar
yes ground wire
Old 10-07-2012, 04:51 PM
  #40
Kc Taylor's Avatar
yes ground wire
ok but will that stop the led to come on at night? because the led is running like a daytime running light right then at night it go off.
Quick Reply: install led headlight
