Low fuel pressuer regulation...DTS
My Q7 has been giving me low fuel pressure regulation error for a while. The error code was P310B - 004.
So, finally I decided to pull a part of that. Because, I wanted to see that what is wrong with the sensor.
And I found a broken O-ring that aroud sensor. So, I replaced the O-ring then, the error code gone.
I hope to help someone who has same issue like me.
Check the sensor's oring.
The low fuel pressure issue could be from small O-ring.
Here are some pictures...
hmmm.... I can not upload any picture.....
Engine: 3.6l fsi v6.
Location: Right back side - when you face the engine in front of the car- of engine, on the fuel Regulator. You may notice yellowish metal piece sticks out of fuel regulator. You can easly twist off with 6in handle 24mm monkey wrench. Afte remove a connector that attach to it.
OrlandoDave
A4 (B7 Platform) Discussion
12-26-2023 01:19 AM
geordie
02-26-2008 05:17 AM
big_anthoiny
10-10-2007 01:25 PM
