Needle sweep on Q7 - is it possible?
#12
The Q7 I did was a 2009, so one would presume the longcoding is a running production change.
So a Canadian Q7 would have a metric face gauge (euro style). You must just have a slightly older model than the one I did.
I was surprised to find longcoding when I did it after reading all the other posts about changing the softcode to turn off the seat chime. It was just an unexpected bonus.
#13
By the way you need the very latest VAGCOM version to get a list of the codes as well.
The previous version I tried initially did not give any details of what each byte meant, just the longcode string.
The latest version has the tick boxes with what each item is.
#15
Just an update. This is the VAGCOM info showing part number for the cluster I did that had longcoding:
Address 17: Instruments (J285) Labels: None
Part No SW: 4L0 920 931 E HW: 4L0 920 931 E
Component: KOMBIINSTR. H06 0133
Revision: 00000000 Serial number: 9IC25Y088
Coding: AF16630408000008010700
#19
Anyone do a needle sweep on US spec Q7
Select]
[17 - Instruments]
[Coding - 07]
[Long Coding Helper]
Click on each of the Byte numbers in step 3) and you'll see the selectable options below.
Check the box for "Gauge Test/Needle Sweep active"
Close the Long Coding Helper by clicking the Windows X box on the top right of the screen or clicking the Exit button on the top left of the screen) will send your new Coding value back to the Coding screen.
[17 - Instruments]
[Coding - 07]
audifirst
VAG-COM Discussion
05-07-2007 05:39 PM
