Oil Consumption
#11
Honda's tend to be bought by gentle, steady, retired folk around here and they do tend to burn oil as a result. As a result? Yes. Honda engines, just like BMW and VW/Audi engines are made of hard wearing durable materials, real quality stuff, which needs to be driven reasonably hard to bed in, certainly not gently driven over the first few thousand miles. In fact Honda engines are the sportiest of all engines as a species, being generally very high revving with maximum power and torque both peaking at very high revs. Very much a young man's engine. Give a new one to a boy racer and you can guarantee an engine that performs to its potential and doesn't use a drop of oil. As long as it is reasonably serviced it will just go on and on with no problems.
#12
I only buy new cars. These have included Honda, MB, Porsche, Audi and VW.
For the first 1000 miles I am easy on the engine - no hard acceleration, no high speeds, no long periods of constant speed and no trailer pulling. The oil and filter gets changed at 1k-2k miles. I, then, start to use the power. Oil and filter are changed at 5k miles and every 5k after that. None of those engines (a dozen or more in the last 25 years) has used any oil after the initial 1k-2k miles.
YMMV, but that is my experience.
#13
I beg to disagree.
#14
My cars may not need oil change and filters every 5k miles, but it makes me happy - especially on the new diesels with oil specifications formulated with far less additives to protect the DPF. Less additives = more wear; which, for me, means 5K oil changes w/filter.
#15
MB used to have a sealed and no service for life recommendation on their auto trannies. "Life" far too frequently seemed to end shortly after the warranty expired; so they have now changed their recommendation: fluid and filter change at 40k miles (60k km).
I do not believe that MB have lowered transmission oil change intervals in Europe other than to specify a change at 100,000 miles where they did say 'life' before. They will last for between 150,000 to 200,000 miles with an average driver without changing the oil but the oil does start to go out of specification at around 100,000 miles. I intend to change the oil in my ZF, which is also 'sealed for life' at around 90,000 miles whether it needs it or not, just like you, because it will make ME feel better.
I know of no wear issues with engines on the flexible drain interval and most engines, unless neglected, and with a bit of luck, last longer than the economic life of the car. Most are scrapped for reasons other than mechanical wear, mainly age related to crash damage, general wear and cost of parts like brakes and exhausts, or just pure lack of any value due to age and no demand. This is a particular problem with larger cars.
I have an Isuzu currently that is 18 years old and is quite roadworthy but is surplus to requirements due to my father's old age and him being stopped from driving. It is mechanically very good but it has a value of £200 as scrap plus the residual value of its road tax. All those oil changes and now it will be sold for some parts and the crusher.
#17
I can't believe what I just read above: It is normal for a 4.2 V8 to burn 3.3 qts/1,000 miles? Seriously? We must be lucky as I have owned many VW/Audi's over the years and have never had an oil consumption issue. Our 3.6 doesn't burn a drop between changes in the 33K we have driven it and our 04 Touareg V8 never burned oil either.
I have only needed to add oil to my Q7 twice. Both times were within a week of getting my oil changed, so I'm guessing the mechanics didn't allow for the extra oil needed when changing the oil filter.
#18
Just got my 2007 4.2l V8 w/ 60,000 miles on it back after my Audi dealer did an oil consumption test. They drained the oil, weight new oil before they put it in. I drove for a 1,000 mile and then they re-weighed the oil. The result were 3.3 quarts per 1000 mile. They said this is w/in Audi's normal range. I brought it in for a check engine light and also told them I had to put 2 quarts of oil in it before and after a trip since my 55k service. They said the check engine light was from a cylinder misfire and that Audi USA recommended the do the test. Ended up putting in a gas detergent and sent me on my way paying my deductible.The light came back on at 125 miles during the test so we'll see what happens now.
#20
I have the same engine. First 5K no problem. Ever since first oil change, been adding a quart about every 1800 miles. Will be contacting the dealer soon.
