Particlant filter pressure error---
We had a problem last week with the TDI that caused the glow plug warning light to flash and the engine to go into limp mode. Wife was about 50 miles from home on a Friday evening. I got online and determined that it should be ok for her to drive on home which she did under reduced power. I scanned the car and that is posted below. Took it to the dealer and they confirmed the particulant filter pressure sensor error and found a TSB that indicated that our TDI fell in a range with defective Particulant pressure sensors. They performed the operations listed in the TSB and all seems good now. Just glad it did not happen last month on our 4600 mile western states road trip!
here is the scan---
Friday,12,July,2013,20:23:21:63511
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Chassis Type: 4F0
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
56 5F 62 69 6C 6D 6F 72 76
VIN: WA1VMAFE6BD007026 Mileage: 63440km/39419miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine (J623-CATA) Labels: 059-907-401-CAS2.clb
Part No SW: 4L2 910 401 HW: 4L0 907 401 D
Component: 3.0TDI EDC17 H18 0002
Revision: 54H18--- Serial number:
Coding: 2A2A4012253600050000
Shop #: WSC 07208 444 05174
ASAM Dataset: EV_ECM30TDI0114L2910401 001002
ROD: EV_ECM30TDI0114L2910401.rod
VCID: E1C2C300F0B13D10CE2
4 Faults Found:
5188 - Diesel Particle Filter
P2463 00 [036] - Excessive Soot Accumulation
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 63378 km
Date: 2013.07.12
Time: 19:06:41
5158 - Diesel Particulate Filter; Differential Pressure Sensor
P2456 00 [101] - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 63330 km
Date: 2013.07.12
Time: 18:38:39
5162 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 61384 km
Date: 2013.06.27
Time: 08:15:33
5189 - Particulate Trap Bank 1
P2002 00 [036] - Efficiency Below Threshold
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 63378 km
Date: 2013.07.12
Time: 19:06:41
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 S HW: 0C8 927 750 S
Component: AL1000 AISIN 001 1818
Serial number:
Coding: 001378
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031.rod
VCID: 3C7CD274B793B0F83D4
No fault code found.
Address 03: ABS Brakes Labels: 4L0-910-517.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099473
VCID: 346CFA5457C378B8F54
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10602901735568
Coding: 0000135
VCID: 254A1710EC19113072A
Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H03 0020
Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AF
Component: KLIMA 4 ZONEN H13 0060
Revision: 00---022 Serial number: 00000030177115
Coding: 0002A036
VCID: 254A17102C19113072A
Subsystem 1 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Component: SLR-B8 H05 0006
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Coding: 070000
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H29 0390
Revision: 00000000 Serial number: 4F0907279
Coding: 0139123
VCID: 6ED8283C796F1268C30
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H17 0100
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD09N3VU
Coding: 0014131
VCID: 2B5EE1288AFD2740A4E
Part No: 4L0 910 339 A
Component: BF-Gewichtsens. H03 0030
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0530
Revision: 00H05000 Serial number: 90026110030166
Coding: 0012042
VCID: 27561D1896150320406
Part No: XXXXXXXXXXX
Component: E0221 H02 0100
Address 17: Instruments (J285) Labels: 4L0-920-xxx-17.clb
Part No SW: 4L0 920 984 A HW: 4L0 920 984 A
Component: KOMBIINSTR. H10 0209
Revision: 00000000 Serial number: FLR53891C
Coding: 8BD664040900CF05020201
VCID: 3162F34068D14D909E2
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 Q HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0047
Revision: MB300033 Serial number: 3300M10C128235
Coding: 00C303
VCID: 3D7ADF70A489B9F00AA
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
2 Faults Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 2
Reset counter: 29
Mileage: 62997 km
Time Indication: 0
Date: 2013.06.30
Time: 18:54:00
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 28
Mileage: 62997 km
Time Indication: 0
Date: 2013.06.30
Time: 21:54:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.50 V
Count: 18
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AA
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---010 Serial number: 00000000263108
Coding: 0000006
VCID: E8D4DE24DB8B4C5809C
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00001002263008
Coding: 00581B00000011110000
VCID: 3260FC4C6DD77688E78
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0050
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E58E83CB9EF5268830
Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H01 0050
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0361
Revision: Serial number: 0008000166948
Coding: 011F57205E40440004
VCID: 4894BEA4FB4BEC58A9C
1 Fault Found:
01705 - Selection Switch for Mirror-Adjust (E48)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 33
Mileage: 63040 km
Time Indication: 0
Date: 2013.07.02
Time: 15:27:41
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 H HW: 4L0 907 289 H
Component: Komfortgeraet H10 0110
Revision: 0110 --- Serial number: 01403625050000
Coding: 3569693
VCID: 356AC7505CB961B0C2A
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 G HW: 4L0 035 223 G
Component: BOSE G3 Q7 H03 0040
Revision: CH003000 Serial number: 00000000020926
VCID: 2648101C511F1A287B0
1 Fault Found:
03278 - Functionality Limited due to Missing Messages
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 19
Mileage: 61387 km
Time Indication: 0
Date: 2013.06.27
Time: 14:44:53
Freeze Frame:
Bin. Bits: 00000001
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H03 0110
Revision: 00000276 Serial number: 00002760046444
Coding: 0758477
VCID: 234E0908E22DEF001CE
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H14 0100
Revision: Serial number: 00000000081985
Coding: 0012001
VCID: DEB8F8FC09CF02E8F30
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0361
Revision: Serial number: 0008000167867
VCID: 4796BD98F655E320A06
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000031
Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Component: AFS-Modul rechtsH07 0004
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471LW0A7550303
Coding: 020007010000000000
VCID: DDBAFFF0C4C919F0EAA
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 4L0 035 664 B HW: 4L0 035 664 A
Component: H-BN-NA H51 0116
Revision: -------- Serial number: 489A10B7544709
Coding: 010200060004E3EF51002305EF6300030000
VCID: 2A50E42C45073E485F8
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Subsystem 3 - Part No SW: 4L0 910 609 HW: 4L0 919 611 C
Component: E0380 Bedient H05 0060
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0361
Revision: Serial number: 0008000165884
Coding: 010E57204040230004
VCID: 4688B09CF15FFA285B0
Address 69: Trailer (J345) Labels: 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H08 0100
Revision: 2A001001 Serial number: 00000137341513
Coding: 0200000000000000
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H05--- Serial number: 525PA8-J0Z40HU
Coding: 1021201
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H56 0500
Revision: --H56001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: ECDCA234CF7360786D4
Part No: 4L0 910 946
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H07 0080
Revision: AAH07080 Serial number: 111209054-----
Coding: 0003595
VCID: 2648101C911F1A287B0
Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H11 0220
Component: J_394_EE16_SKB10H11 0220
Component: J_392_EE16_SKB10H11 0220
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H11 0361
Revision: Serial number: 0008000165887
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
Component: Parkhilfe 8-Kan H03 0500
Revision: 00H03000 Serial number: 37331035016419
Coding: 0231266
VCID: 2A50E42C85073E485F8
End ---------------------------------------------------------------------
here is the scan---
Chassis Type: 4F0
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 63378 km
Date: 2013.07.12
Time: 19:06:41
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 63330 km
Date: 2013.07.12
Time: 18:38:39
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 61384 km
Date: 2013.06.27
Time: 08:15:33
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 63378 km
Date: 2013.07.12
Time: 19:06:41
Serial number:
Coding: 001378
Revision: 00H02001
Coding: 0099473
Coding: 0000135
Coding: 0002A036
Coding: 070000
Coding: 070000
Coding: 0139123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Coding: 0014131
Coding: 0012042
Coding: 00C303
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 29
Mileage: 62997 km
Time Indication: 0
Date: 2013.06.30
Time: 18:54:00
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 28
Mileage: 62997 km
Time Indication: 0
Date: 2013.06.30
Time: 21:54:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.50 V
Count: 18
Coding: 0000006
Coding: 0010001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 33
Mileage: 63040 km
Time Indication: 0
Date: 2013.07.02
Time: 15:27:41
Coding: 3569693
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 19
Mileage: 61387 km
Time Indication: 0
Date: 2013.06.27
Time: 14:44:53
Freeze Frame:
Bin. Bits: 00000001
Coding: 0758477
Coding: 0012001
Coding: 0000031
Coding: 1021201
Coding: 0003595
Coding: 0231266
KnappAttack
06-28-2018 05:05 PM
Reggie
RS4 (B7 Platform) Discussion
06-10-2010 09:25 AM
