Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
The Q7 is great!!! Just one niggle the Audi Side Assist - System Fault
Old 03-18-2007, 03:13 AM
merc_320's Avatar
Default The Q7 is great!!! Just one niggle the Audi Side Assist - System Fault
Took the fuse out, and it made no difference. Dealer will be looking at it on Tuesday. Great feature whilst it worked.
Anyone else with this?
Old 03-18-2007, 03:22 AM
mksap11's Avatar
Default Mine failed within the first 150 miles. One of the CPUs had failed...
It was replaced at dealer without incident and we've been problem free since (~3 months). Your dealer will likely have to order the part, so plan on making 2 trips. For us, the part only took ~2 days to arrive and our dealer provided me with a free loaner both times - an A4 and a Merc C-class.
Old 03-18-2007, 03:45 AM
merc_320's Avatar
Default Cheers for that. Mine went at 300. Where is the CPU?
Any ideas on how it happened. Is it because of Radar Jammers or something?
Old 03-18-2007, 04:04 AM
mksap11's Avatar
Default The CPU is located behind the rear bumper cover..
so they have to take it off to access the CPU. Once they put everything back together, they will also recalibrate the Side Assist system. In my case, the CPU simply failed. I had scanned the car with my VAG-COM and came up with this error code:
VAG-COM Version: Release 607.3-UD
Control Module Part Number: 4L0 910 566 A
Component and/or version: J0769_SWA_MasterH06 0060
Software Coding: 0000001
work Shop Code: WSC 31414
Additional Info: 4L0910568A J0770_SWA_Slave_H05 0060
Additional Info: Geraet 00001
1 Fault Found:
16365 - Control Module - Electrical Error; CPU 2
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset Counter: 7
Mileage: 216 km
Time: 16:7:20
Old 03-18-2007, 04:13 AM
merc_320's Avatar
Default Oh man! didn't think my car would be taken apart so soon.
I know the radars were in the bumper but thought it might be located somewhere easily accessable.
Old 03-18-2007, 04:25 AM
mksap11's Avatar
Default I know what you mean! The good news is that the bumper removal is fairly straightforward
but time consuming. A lot of parts have to come off to get to the SA modules, but they're mostly all body pieces. My dealer really did a great job with it, though, the recalibration of the SA when the bumper is removed is one reason why I'll probably never install a hitch on my Q.
Old 03-18-2007, 05:19 AM
merc_320's Avatar
Default Just looked at ELSA & the removal is straightforward (1 Page) but the Calibration isn't (10 Pag
Did they do the calibration right? Do all the dealers have the equipment to do it? As only the Q7 has the feature and is relativly new. Worried they may not bother.
Old 03-18-2007, 05:24 AM
mksap11's Avatar
Default Yes, it seems like they calibrated it correctly. if anything, the system is a bit more conservative
than my driving habits, but that's really more of a problem with my driving style ;-) In all honesty, I hadn't driven the car enough before it failed to be able to tell you if the behavior changed from before. It works, and works well (except during a heavy snow storm where snow piles up on the bumper), so I can't complain.
Old 03-18-2007, 10:08 AM
AvantMore's Avatar
Default Mine's out too. Wonder how prevelant this problem is.
My SA failed during a big sleet storm about 2 weeks ago and I thought that might have had something to do with it. I've been trying to figure out if it could be reset somehow. I was about to post a message asking for advice. Oh well...
Bummer, off to the dealer this week...
Old 03-18-2007, 10:44 AM
mksap11's Avatar
Default Is it still not working? Snow/sleet/etc collecting on the back of the truck will
cause it to disable itself temporarily. if you push button adjacent to the memory seat buttons to reactivate it but still get the "Side Assist System Fault" in the DIS, you probably have the same problem that we do.
Quick Reply: The Q7 is great!!! Just one niggle the Audi Side Assist - System Fault
