Q7 Radio
I have a 2010 Q7 Premium Plus with the MMI/Navigation.
Yesterday, upon turning off the car, the radio stayed on (display and sound). Tried locking the doors to see if it would turn off, and it stayed on. Had to go back in the car, put the key in the ignition and turn the car on and off again to get the radio to turn off, anyone else see this problem before?
I hope my new q7 with only 1k miles doesn't have those weird German electrical bugs starting up already......
If you accidently rotate the volume control on steering wheel or console even after you switch off everything you will restart radio C/W screen. It will auto shut off after 20 mins IIRC. Pretty sure it stops if you press lock button.
In my Q7 radio will go off after 15 minutes if I put it on without key in ignition.
To turn it off I can just hit the volume on the middle console but this does not turn off the MMI. It goes off if I just insert the key and remove it again. No need to start and stop the engine. Just pull key out and it shuts off the MMI.
Arrie
AudiSQ5owner
Q5/SQ5 MKI (8R) Discussion
08-06-2018 08:37 AM
sow
12-13-2009 07:31 PM
