Q7 Rear Caliper bolt. What bit/tool size needed
Can anyone tell me what size bit or tool is needed to remove the caliper bolts on a 2011 Q7?
Thanks in advance.
Thanks in advance.
This is not true. I have a b8 A4 3.2L. And did all brakes and rotors. The front all u need is I believe a 21mm socket to take the from caliper off. And a big breaker bar or ratchet. And a C clamp works just fine to collapse the piston. As for the rear. You don’t need Vagcom to collapse the rear piston. I watched a YouTube video. You can take the hosing off the caliper with a torx socket and when you remove it there is a torx inside the housing turn it I believe counter clockwise all the way and then you can collapse the rear caliper with the C clamp. And then reinstall everything. Make sure you pump your brakes prior to anything to get everything tight again.
Its a Triple Square, M16/16mm IIRC.. it was the 2nd largest one in this kit:
Its a total bitch bolt to get out too, be prepared to hulk the crap outta a breaker bar to get it off.
This is a Q7 forum, its different than an A4 significantly.. rear calipers can be collapsed just by squeezing on em w/the old pads.. you dont need any tools to retract em unless you got weak girly hands.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
09-01-2015 11:57 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
