Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Q7 Suspension problems....
Old 12-15-2015, 08:32 AM
  #11
Canadian Lurker's Avatar
So the suspension controller probably has a default to assume a door is open if it doesn't get a proper response from the door control module. Therefore, these codes will have to be rectified too.
Just don't know the order of operations if you should deal with the door module first or the suspension module.
Old 12-15-2015, 01:41 PM
  #12
Jeliz's Avatar
Hi Audi People,
Sorry to post in here, since i am new i can't start a new thread? I just turned in my wife's leased 2012 Q7 and i have a Weathertech black mat that goes behind the 3rd row of seats. Does anyone need one that is near 1000 Oaks, CA, if not PM me and i can ship it to you....it's free
Old 12-16-2015, 05:26 AM
  #13
Edd W's Avatar
Close the doors and clear all codes with your laptop plugged in through the drivers open window then straight away see if you can run the adaption process. It may well not see the door open status then.
Old 05-27-2016, 04:38 AM
  #14
omy1913's Avatar
Hi guys
sorry to bring up an old thread but I am having such a nightmare with my Audi Q7
Its a 56 reg Audi Q7 3.0 TDi S Line
About 2 months ago I heard the compressor running even when the engine was off and eventually after a few hours the back end of the suspension dropped and options to raise/lower the suspension didnt work. The front end stayed exactly where it was.
Figured the compressor had packed in, bought a second hand one, had it fitted and everything was back to normal, well atleast I thought it was!
2 days later after coming off the motorway the compressor started making some weird noises, clunking and clicking and all sorts even with the engine off. The following day the back end of the suspension dropped again and option to raise and lower the suspension grayed out on the MMI. I thought maybe a sticky relay caused the 2nd pump to contentiously stay on and burnt it out again (stupid mistake of mine not to change the relay the first time!)
So got another air compressor, fitted it in along with a new relay and nothing, all the options on the MMI are available to select but the suspension is does not move, since all the airlines were disconnected when changing the compressor ect the whole car is dropped to the ground now all around. I then thought maybe it is a module fault, so got a new air suspension module but that didnt work either.
Its now been about a month and the car has just been sitting on the driveway looking miserable (between being busy at work and being on holiday, the car has not received any time from me)
I am getting the following codes on vcds along with the flashing air suspension warning lights on the dash:
02250 - Function Deactivation; Valve Duty Cycle
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 168
Mileage: 218085 km
Time Indication: 0
Date: 2016.05.26
Time: 20:51:49
Freeze Frame:
Error Code: 46
01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
008 - Implausible Signal
Freeze Frame:
Fault Status: 11101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 8
Mileage: 218085 km
Time Indication: 0
Date: 2016.05.26
Time: 20:53:57
Freeze Frame:
Error Code: 30
01577 - Turn-Off due to Over-Temp
Freeze Frame:
Fault Status: 11100001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 8
Mileage: 218085 km
Time Indication: 0
Date: 2016.05.26
Time: 20:54:00
Freeze Frame:
Error Code: 68
I have also read the values on ch04. 05 and 10:
If anyone can shed some light and point me in the right direction it would be much appreciated.
Very kind regards
-Omy
Old 05-27-2016, 06:46 AM
  #15
Edd W's Avatar
If there is now nothing working, I would suggest the main 20amp fuse has blown. I am not sure where it is located but goggle will probably give you the answer.
Once you have it running again - and it should not run unless the ignition is on so it sounds like the relay was sticking, see what happens - clear codes and start from scratch.
Old 05-27-2016, 09:10 AM
  #16
omy1913's Avatar
Firstly many thanks for the speedy reply Edd,
We've checked the fuses a number of times and they all seem fine.
Just cannot get my head around it.
Do you think it could be the rear level sensors?
Also does the screenshot of the readings make any sense to you?
many thanks once again
Old 01-23-2020, 01:54 AM
  #17
yofatim's Avatar
Hello, I would like to pick up on this old topic, I have also recently had a problem with my air suspension, I get three error codes, 1577.1400.2250. As soon as I start driving, the yellow light starts flashing. I have VCDS. Can someone help me how I can identify the problem? Does anyone know how I can test the different sensors?
In the meanwhile I have read out with VCDS:01577 - Turn-Off due to Over-Temp
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 232898 km
Time Indication: 0
Date: 2020.01.20
Time: 08:12:59
Freeze Frame:
Error Code: 68
01400 - Suspension Level Control
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 63
Mileage: 232938 km
Time Indication: 0
Date: 2020.01.21
Time: 17:07:36
Freeze Frame:
Error Code: 66
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 63
Mileage: 232933 km
Time Indication: 0
Date: 2020.01.21
Time: 16:57:01
Freeze Frame:
Error Code: 46
Anyone some hints?
benpitt
169
12-09-2018 11:52 AM
Eddyg
01-23-2016 07:54 AM
Trackballcr
Audi allroad
08-29-2010 04:28 PM
mjeakman
Audi allroad
02-07-2009 05:06 AM
JGallroad
Audi allroad
04-01-2008 02:38 PM
Quick Reply: Q7 Suspension problems....
