Q7 Top Speed?
Just curious, I read online that the my 4.2 is governed at 130, given, the speedometer on 2007-2008 models goes up to 160, 2009+ goes to 180. I can't imagine the Q7 driving at 130mph. I feel it would not be able to reach those kind of speeds, like it really matters though.
Jim VP
US Spec Q7s are limited to 130 MPH. I can tell you that you can set the cruise control at 130 and it will hold all day. Germen spec Qs will blow by you. Having just returned from Germany, I attest that the Q7 cruises comfortably at 120-125 at just under 3k RPM. Missing the Autobahn!
I hit 130-135 last weekend on the way to Wendover pretty effortlessly. I'm running the APR tune, not sure if that bypasses the factory governor but it was still pulling. I am however running 22's so I'm not sure how accurate that speed is.
AudiWorld Expert
GIAC & APR Tune remove top speed restrictions.
22" Wheels will display a slower speed than actually traveling if the overall rolling diameter larger than the oem wheel.
On European ones we have the 155 limiter, in my 4.2tdi this was removed when mapped as I think the stated top speed is something like 150 out of the factory for the later more powerful 8speed version.
Audi Q7 4.2 TDI | Autocar they say they can vouch for the older versions 147 top speed!!
Btw, did you notice a difference in acceleration off the line and at cruising speeds after you got the APR chip? I am considering pulling a trigger on this
I assume you have the TDI, as your signature states
